![]() Join Date: Feb 2010
Replaced dual mass flywheel and clutch, Still rattled. Code 44(LH O2 sensor,lean) Replaced O2 sensor,because it was easy,and sometimes it idled smooth sometimes it idled rough ,Still rattling.SO I took it to my southeast ZR-1 specialist.He removed the plennm cleaned all the injectors checked the wires and coils put it back together and it did the same thing.Off with the plenuum again.bench tested the injectors,checked compression(191-201)and then was able to determine that the NO #7 cylinder wasn't fireing all the time.He then found a broken wire 6 inches up the harness that was making contact intermittently.No rattle and the car runs like a scalded dog.Big time Thank You to Aaron Scott of SGC.
Gary 90-1572 ![]() |
#3 | |
Im assuming the fuel rail harness... Id imagine they get crispy over time.
#4 | |
Daryll.....got wheels balanced this morning with those new brakes......120mph and no vibration...just have to watch for Combines with 24 row corn heads ![]()
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 10-18-2013 at 11:35 AM. |
Yep perhaps or perchance an intermittent electrical queertron
Yea the wire was going to the #7 primary injector. The break was up in the harness about 6 inches where they are all together.
