Old 10-06-2013   #1
QB93Z
QB93Z's Avatar
Default WTB - Door Handle - driver's side
I need to replace the door unlock switch on the driver's door. I think that I will need to buy a door handle that includes the switch and then cannibilize the switch from it.
Thanks,
Old 10-07-2013   #2
WVZR-1
Default Re: WTB - Door Handle - driver's side
Which car? The switch is different on a '90 and it's likely only a difference in the electrical connector but if it's for a '91+ car you might want to make sure you source the correct switch. That would allow you to avoid the cut/splice or swapping terminals and the connector. I have no first hand knowledge of the difference.
The switch is '89 and earlier, '90 a single year application and then '91+ by part number.
Old 10-07-2013   #3
QB93Z
QB93Z's Avatar
Thanks for the information Dave. I need the switch for the 1994, but I will take anything that will work even if I have to swap connectors.
Old 10-07-2013   #4
Blue Flame Restorations
Jim, try Y-ME here on the Registry. He's parted several 91-95's and is in Maryland.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 10-07-2013   #5
QB93Z
QB93Z's Avatar
Thanks to David J for a good lead to Shawn at CorvetteNutz
(Shawn@corvettenutz.com. 760-845-1308)
I located the part and it is on the way.
Thanks for everyone's help.
Old 10-07-2013   #6
DaveK
Glad you're not going to have to do a "Dukes of Hazzard" type thing!
Dave
1991 #1516 Black/Black
davidmkelly.com
Old 10-16-2013   #7
Y-me
Maryland?
Y-me is offline   Reply With Quote
Old 10-17-2013   #8
zrwhat
zrwhat's Avatar
Originally Posted by Y-me View Post
Maryland?
Well close enough!
zrwhat is offline   Reply With Quote
