Where is it?
I need to do pressure test with a jumped 12V source, since everything is dis-connected here... 'UNDERHOOD' - narrows it down a little... The first schematic already shows it near the drivers side somewhere. Anybody got a snappics here? Last edited by Schrade; 10-14-2013 at 11:10 PM. |
Thanks there Cliff...
Marc says 43 is good enough; FSM says 48 is minimum. ![]() |
Does this look like an OEM test connector?
![]() Join Date: Sep 2013
90% sure that is it. but there are others that know more than I.
![]() Join Date: May 2013
Schrade, on page 6e3-a-6 in FSM it says" 490red Fuel pump test connector located near battery. Must be the one you found. Goes to terminal 3 of pri fuel pump relay.
Concerning the fuel question. I want to make sure I understand what is being said here. The FSM indicates ign on - engine off pressure to be 48-55 PSI. Then ign on - engine idling fuel pressure to be 3-10 PSI less indicating regulator control is functioning. FSM then indicates approx. 43 PSI in idle. Is that what Marc is indicating? Static versus dynamic pressures.
#10 | |
Dynamic idle with vacuum was 40 (I haven't seen his spec for THAT). I saw in FSM that spec drop dynamic is 3 - 10, so I'm good there. Need his feedback on it... I'll test again when everything is dry-fit - yep all together dry, and dis-assemble AGAIN - familiarity, sequence, KNOWLEDGE ![]() Thanks again there................... |
