Old 10-11-2013   #51
Default Re: Throttle hesitation diagnostics?
swap the fuel pumps. Make the secondary the primary and the Primary the secondary. See if the swap changes the stumble.
just an idea
Old 10-11-2013   #52
Does the stumble continue if you keep the pedal at a steady 1.6% TPS? Or does it stumble on the initial tip in?
Old 10-11-2013   #53
Blue Flame Restorations
I just put pumps in the 95 a week ago. Easy peasy.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 10-11-2013   #54
Schrade
No 'cautions', or 'gotcha's' on it there Brett???
YES - although it's a lope, no 'stumble'.
I'm gonna' do another vid here momentarily, with engine running to show DM readouts in sync with engine lope...
Old 10-11-2013   #55
Nope. Real straight forward. Checkout Dynomite's Solutions. Takes about an hr first time through.
Old 10-11-2013   #56
Franke
Since the fuel pressure increases to maintain regulated pressure when the vacuum drops (opening throttle) then removing the hose should tell the FPR to increase fuel pressure. The FSM does talk about that in Emissions and drivability. I wouldn't do this for long periods of time with the FPR to prevent problems in case of injector malfunction. Follow chart A7 to check FPR on page 6e3-A-29&31. Maybe that will help.
Scottfab once said in another post that fuel pressure as low as your was (44psi) is too low. According to FSM I would have to agree. Performance issues could crop up but I'm not sure it would cause your hesitation at just off idle.
Old 10-15-2013   #57
Should I pull the IH's next? Or DIS?
Pull the His....the DIS is under the Plenum with four bolts. That is already pulled with the Plenum.
And are you removing the starter and AC compressor?
If so on the AC compressor....you just set that aside but be very very careful you do not put a bending load on the AC lines going into the evaporator.
I assume you are pulling the starter and cleaning out the Valley Drain also.......and maybe pulling the crankcase breather cover and installing new gasket.
And since you have starter removed....take the Solenoid apart and clean up the contacts when you are at it.
Old 10-15-2013   #58
Schrade
Yep - got to roll the AC comp aside - dropped a bolt for mounting one of the 4 the ?'s (distributors) (above the starter), at the PS pump. Another hunting setback.
Di-electric grease after cleaning, on the contact prongs at re-assembly???
Breaktime on breakdown; cleaning parts ahead...
Old 10-17-2013   #59
Default Re: 1990 top end restoration
http://www.youtube.com/watch?v=FsqJFIJ5lLs
Old 10-18-2013   #60
Exclamation Re: 1990 Throttle hesistation
By request. I split the threads. GC
