Old 09-17-2013   #1
92whiteZ
Default SoCal windshield shop
Hello,
anyone in the Los Angeles/So Cal area who has a trusted windshield shop? My 92 has an original windshield with only the slightest of delamination. wanted to swap it out and store it. Haven't had any luck with good replacement shops so I welcome any recommendations.
thanks
92whiteZ is offline   Reply With Quote
Old 09-17-2013   #2
John Boothby
John Boothby's Avatar
Default Re: SoCal windshield shop
From what I have read, removing it and storing will not stop delam. I am not 100% but even nos windshields have been known to have delamination.
JB
1990 #148 Red/Saddle
Haibeck AYBKG5 Chip/RC Engineering/Flowmasters/K&N/Samco/Fuzzy Dice
:cheers:
Old 09-17-2013   #3
92whiteZ
that's good info to consider. appreciate it.
Old 09-17-2013   #4
True case in point the last ZR-1 at the NCM museum it has the worst delam I have ever seen
Old 09-17-2013   #5
Interesting my Callaway TT sat in the AZ sun for years. I was working on the dist and the windshield shattered from leaning on it.....when they replaced it the glass company pointed out the materials used to laminate the glass rot and get brittle.......sun degrading, air/humidty getting under the layers of glass, and safety material all cause this
To save it you would need to reduce exposure and seal the edges from al air/humidity, etc
Old 09-17-2013   #6
I agree 100% and even the best glass people say the windshield is likely to crack when uninstalling the windshield
If its good, keep it in!
Old 09-17-2013   #7
ghlkal
ghlkal's Avatar
Yup ... here's the image
Old 09-18-2013   #8
92whiteZ
You all know your stuff. Mine has very very minor delamination at the very edges but it sounds like its b3st to keep it in until it becomes an issue
Old 09-20-2013   #9
ZRXMAX
ZRXMAX's Avatar
I won the "Delamination Award" at the west coast ZR-1 triathlon in 2006!
You should see it now !
Its ready to be replaced just from the pitting after 120K+ miles. I was also considering a windshield polishing system as a way to minimize the obstruction of vision when driving towards the Sun.
91 ZR-1 #661 Watsons, 3" exhaust, Borlas... Hurst, 4.11s, Samco, RD radiator, gel coated motor... turquise / black
ZRXMAX is offline   Reply With Quote
Old 09-20-2013   #10
ZRXMAX
ZRXMAX's Avatar
That delamination should make it a 101 point car... eh ?
