Old 08-15-2013   #1
Gkpipe
Default car will not crank sometimes untill it cools off
I have a 1994 it sometimes will not crank when hot and I have seen "SYS" flashing in speedo sometimes? I did bypass the chip on the key and still have problem. any ideas
Gkpipe is offline   Reply With Quote
Old 08-15-2013   #2
Franke
Default Re: car will not crank sometimes untill it cools off
I've seen this come up as a bad starter motor or defective wiring connection between the starter and battery. SYS could be flashing due to a heavy drain on the battery when trying to start. Check battery voltage with a digital voltmeter when trying to start hot. Voltage should stay above 10.5 or so according to some manuals. IMHO. Any others got some insight?
Old 08-15-2013   #3
Concur
Starter Relay, Wiring Harness, Battery, and Plugs Tricks
Old 08-18-2013   #4
Gkpipe
I have a new batt I have been told to replace the starter relay under dash some where? allso was told it could be bad control modual? has anyone heard of that?
Old 08-18-2013   #5
Starter Solenoid is heat soated.....has the starter been replaced???
Old 08-18-2013   #6
scottfab
scottfab's Avatar
Time to measure some voltages (unless you just want to start replacing things)
When it won't start measure these with the key turned:
1. From the engine block to the Pos on the battery
2. From the Neg to the Pos on the battery
Don't assume a new battery is a good battery.
From there, assuming above ~11V other places should be measured....
Scott
Old 08-22-2013   #7
Gkpipe
car has 20k on it I believe its the starter that came with the car. will check voltages next time it dont crank but I feel as if the batt is fine. was looking for the location of the starter relay?
Old 08-22-2013   #8
scottfab
scottfab's Avatar
It's going to be under your left knee cap. You'll have to remove the cover but that is only a couple of screws on the front part and I think one fastener toward the firewall. On your car (not mine) it should be the relay closest to the steering column.
Scott
Old 08-22-2013   #9
Gkpipe
thank you we will give it a try
