Old 08-15-2013   #11
Default Re: Injector Housing to Head Port Match Issue
Greg VanDeventer from Mercury Marine????
Old 08-15-2013   #12
KJL
My bad is name is Mike Ebert.
I may consider it. Blending the head port to the intake would also eliminate the oil/fuel from collecting there working its way through the gasket.
I figure I would use a long scribe and mark the heads while the intake is still on the head.
1995 ZR1 #159
Ported,Corsa,4.10 Rear, Dual Disc RAM Clutch, Alum Flywheel, Haibeck Chip, ZFDoc Plates, Relocated Battery 400 rwhp
1992 ZR1 #280
Ported, Locked Secondary's, Flowmaster Exhaust, Haibeck Chip, 375rwhp
1996 Collectors LT4 (Stock)
1972 Convertible 434 Small Block
572 rwhp
KJL is offline   Reply With Quote
Old 08-15-2013   #13
KJL
I wonder what it cost to ship?
1995 ZR1 #159
1992 ZR1 #280
572 rwhp
Old 08-15-2013   #14
Reference: Jerry's Gaskets are port enlarged to 36.5mm and precision die cut to dimensions from original engine drawings, so they make an ideal template to work from. They retain the bifurcation between the primary & secondary ports for stock applications.
You would benefit in the long run by using a set of correct gaskets as a reference for both the injector housing and cylinder head ports to match them up. Then, you can use a new set of gaskets without having to trim to match. At this point, it's not known if the injector ports are correctly located. I have seen significant core shift in early housings. I wouldn't recommend matching your Dunn heads to a set of injector housing that are not ported correctly.
BTW, you also have Aaron Scott, South Georgia Corvettes, in Thomasville, GA. He is closer to you and very well versed in the LT5.
Old 08-15-2013   #15
Default Difference between 90' and Later IHs and Plenums
Then there are the Crankcase Ventilation (CV) differences between 90' and 91'-95' Injector Housings as Jerry described
90' and 91'-95' Injector Housing Differences
For which a modification exists if you install a 91' IH on a 90' Head for example.
I do not think there is an issue installing 90' IH on later Head as you would only end up with CV double restrictions vice NO restrictions going the other way.
Kind of like trying to mix 90' Plenums with 91' and later Plenums which look/fit the same but have differences in Charcoal Canister Vacuum connections. The charcoal canister for 91' being located by gas tank and the charcoal canister for 90' located under drivers side head light
Old 08-15-2013   #16
How did you get your car to Marc's? That would be a cool thing to do but the logistics of it would be a challenge. Too bad there is no one in the Atlanta area. How long have you had the car?
KJL,
Drove it up on Sunday nite, I got old Blue in 2002 also had a 1990 Black/Gray for many years. I only know of about 3-4 others in this area. We need to meet up sometime.
Steve
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 08-15-2013   #17
Locobob
I don't see anything really wrong here, just looks like a ported injector housing on top of an unported head. In my experience plenums, injector housings and heads all exhibit some degree of port "skew" from the factory. You'll pick up some power if you port match the top of the head ports to the injector housings but I don't see where what you have now is hurting anything.
Robert
Old 08-15-2013   #18
dunno how close you are to aaron but check out http://www.southgeorgiacorvette.com/
Old 08-15-2013   #19
KJL
I have attached a picture showing the top side of the FI housing. It appears they were Siamese ported. Is this typical? Also, the secondary ports line up perfectly with the heads. The primary ports on the FI housing seem to all be oversize and they all line up perfectly with the head port side that is adjacent to the secondary port. After I remove the FI housing I am sure I will learn more including why the mysterious oil leak.
The previous owner said the car dyno'd at 389 rwhp.
1995 ZR1 #159
1992 ZR1 #280
572 rwhp
Old 08-15-2013   #20
Locobob
What you have there is a partial siamese or figure 8 porting job. Typically you'll find this style on more aggressively modified engines i.e. 368's, strokers, it is probably not doing much extra given your engines relatively low state of tune - doesn't hurt anything though.
Robert
