08-03-2013 | #11 |
Re: New Owner with Q's
Yes indeed welcome to the party. Lots to learn.
One way to learn bunches is to use the "search" feature of the forum. Go to the Technical section for instance and search for "clear codes". Read up. You might also try "read codes". There is a cumbersome but effective way to do it with just a shorting strap(wire). Or you can buy that appropriate scanner to do it for you. How does she run with the power key off? No need to trouble shoot the secondary system if you've got issues when they are not engaged. If all runs fine with the power key off then assume, as has been mentioned, fuel pump and/or injectors and/or vacuum leak issues. The leak you've described does sound like the check valve. If you're going to pull the plenum consider cutting some gaskets yourself out of rubber. They can be used over and over without coming apart. Regular inner tube rubber works but you can find large sheets of the stuff on line. When the plenum is off you can use it as a guide for cutting the new gaskets. One thing at a time. I'd suggest a separate thread per issue. It's not only easier to focus on the task at hand but can also be reused/found in searches by future forum users.
08-03-2013 | #12 | |
[I][FONT=Comic Sans MS]John Boyd[/FONT][/I] [I][FONT=Comic Sans MS][SIZE=1]Ideho[/SIZE][/FONT][/I] [FONT=Comic Sans MS][SIZE=1][I]2015 ZL1 [/I][I]Camaro #1121 BLACK/BLACK 6 SPD (540 RWHP)[/I][/SIZE][/FONT] [I][FONT=Comic Sans MS][SIZE=1]1991 ZR-1 #458 [COLOR=red]RED/[/COLOR][COLOR=black]BLACK 72[/COLOR]k miles ([B][COLOR=red]SOLD[/COLOR][/B]) 1991 ZR-1 #473 [COLOR=red]RED/[/COLOR][COLOR=black]BLACK [/COLOR]37k miles ([B][COLOR=red]SOLD[/COLOR][/B])[/SIZE][/FONT][/I] |
08-03-2013 | #13 | |
So PCV first, if not, then cam cover vents.
[SIGPIC][/SIGPIC]Former Membership Chairman Former ZR-1 Registry - BOD 1972 Corvette 4speed base Coupe SOLD long time ago 1984 Corvette Z-51/4+3 SOLD 1992 Corvette ZR-1 Aqua/Gray #474 SOLD 1992 Corvette ZR-1 Black Rose/Cognac #458 2014 Honda VFR Interceptor DX Last edited by XfireZ51; 08-03-2013 at 09:58 PM. |
08-03-2013 | #14 |
Ok, thanks for all the replys and suggestions. Hammer, I'll try the tip you mentioned tomorrow.
Regarding the smell, I have to admit what was determined.... a little embarassing.... it would help if I didn't slip the cluth at high rpms. That problem is solved! Took it to the track, today. Wow, what a blast to drive! This car is awesome and can really pull. It really is a beast. At some point, I'll write up a comparison of how this car drives compared to my '04 Z06. They really are very different. Handling goes to the Z06, fun award goes to the ZR-1, and since I'm not trying to win an award on the track; I like the ZR-1! Its funny, I had a decent amount of comments on it being a ZR-1 and a few people seems agast that I was willing to risk tearing up the ZR-1 on a track versus keeping it in my garage clean & safe. Other than the wheel bearings, this car seems to be very well put together and feels really solid on the track.
[CENTER][SIZE=4][COLOR=red]1990 ZR-1 Red / Red[/COLOR][/SIZE][/CENTER] |
08-03-2013 | #15 |
The motor is bulletproof. You can't kill it accidentally. So u can drive the p*ss out of it. More so than an LSx. Something else will give out before the motor.
