Old 07-18-2013   #21
emmvette
emmvette's Avatar
Default Re: Finally completed coilover and sway bar install, plus Christmas came early
Looks great! How much time did that work take? Looks like a worth while project!
emmvette is offline   Reply With Quote
Old 07-20-2013   #22
CJ_ZR1
It takes 6-8 hours if you have all the parts ready at once. You have to get a grove machined onto each shock. The whole project took me 2+ months but I only worked on it when my friend and I had time. Well worth the time and effort.
CJ_ZR1 is offline   Reply With Quote
Old 07-21-2013   #23
HAWAIIZR-1's Avatar
If you don't mind sharing, how difficult is it to get the groove put on the shocks and what are the locations? The instructions from DRM did not state and I could not get a reply from Randy.
Glad to hear you are enjoying the coilovers and the install went well.
Thanks!
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 07-21-2013   #24
Thanks!
Marc H. can get the shocks grooved. $80 for the 4 of them.
Old 07-21-2013   #25
HAWAIIZR-1's Avatar
Thanks so much and that is awesome. I'll get with Marc and I appreciate the tip.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 07-22-2013   #26
CJ_ZR1
I sent my shocks to DRM for machining. Only had to pay shipping, machining was included in coilover purchase. Shocks are machined right about an inch (26mm) from where the shock starts to curve in at the bottom.
Old 07-23-2013   #27
carter200
carter200's Avatar
CJ,
What's the width of the groove and the diameter of the shock? Thanks.....
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 07-23-2013   #28
HAWAIIZR-1's Avatar
CJ,
I can't thank you enough for taking the time to share detailed photos like this. I really appreciate it and will check with Randy at DRM. Pictures are worth a thousand words as the saying goes and now I understand what is being said about it.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 07-24-2013   #29
CJ_ZR1
Shock width is 50.28mm
With snap ring total width increases to 53.28mm
The ring is roughly 3mm thick and the grove in the shock body is cut 1.5mm deep. The ring is also roughly 1.46mm thick.
Hope this helps
Old 07-24-2013   #30
5ABI VT
Car looks awesome !! I'm curious .. What kind of an airbox is that I see on a few zr1s? Looks aluminum/metal ??
