Old 03-28-2007   #1
crazyb1
crazyb1's Avatar
Default New starter
My starter bit the dust. I have the plenum pulled (that was fun!!!) and I'm trying to find a new, not reman, starter for under $200. Does anyone know where I can find one? Nopi racing doesn't show a new, or reman for $112 (Bosch). Can anyone help?
Crazy
crazyb1 is offline   Reply With Quote
Old 03-28-2007   #2
jonszr1
jonszr1's Avatar
Default Re: New starter
ck ebay the partsladi. good prices and i believe a new starter.
Old 03-28-2007   #3
Gunny
Gunny's Avatar
I agree
Gunny is offline   Reply With Quote
Old 04-04-2007   #4
crazyb1
crazyb1's Avatar
Success!!!!! The beast is back! After three hours on starter installation and putting everything back where it's supposed to be ( I hope. No extra parts or things unplugged) #1239 is back in business. Apparently on first start up, I had drained some anti freeze into the motor and it smoked white for about five minutes. I was worried at first but then it went away. Another curious thing happened: My motor burns some oil and there was always a small hint of smoke from the exhaust prior to my plenum pull. I don't know what I did different, but the smoking has appeared to go away. I'll have to watch the oil consumption over the next few weeks to see if there are any changes. What could cause this if only a plenum pull is performed? Thanks for all of your guys' inputs on this thread, as well as others I've used. I'm not that mechanically inclined but I figure why pay labor to a guy who's never worked on a Z when I can save the $$ (for gas) and do it myself.
Old 04-04-2007   #5
jonszr1
jonszr1's Avatar
did you di anything with the pvc hose or valves? like clean them that would / could change them
Old 04-04-2007   #6
crazyb1
crazyb1's Avatar
All I did was reconnect the PCV valves. It felt pretty loose so I may have to use a zip tie to keep in place. Whatever I did, it worked.
Old 04-04-2007   #7
tf95ZR1
tf95ZR1's Avatar
Hey Crazy
Did you replace any gaskets?
Maybe an old one was leaking.
Ted
Old 04-04-2007   #8
crazyb1
crazyb1's Avatar
I re-used the existing gaskets. Maybe everything is just a little bit tighter under and around the plenum.
Old 04-04-2007   #9
guinnessdood
guinnessdood's Avatar
My guess is that the smoking will return...mine smokes a little too...it's a 90 with ~ 40K miles.
guinnessdood is offline   Reply With Quote
Old 04-04-2007   #10
jonszr1
jonszr1's Avatar
did you have an idle (high) problem before you pulled the plenum? Im thinking that your fix on the pvc line caused the engine to have a better seal and suck less oil into the plenum. I could be wrong its just a thought
