Old 06-24-2013   #1
Scrrem
Scrrem's Avatar
Default Passenger Dash Carpet
Those who have done color changes in their Z, has anyone attempted to remove the carpet piece under the passenger side, below the glove box. The carpet is glued to the plasic dash. It looks really tough to remove without damaging the carpet or the plasic underneith. Since I am going from Saddle to Black, I am seriously considering dying the piece in place.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 06-24-2013   #2
WVZR-1
Default Re: Passenger Dash Carpet
I would think the preferred might be to transfer the correct carpet and I don't know why a commercial "heat gun" might not allow it to easily be removed. It actually was a service part that was sold as separate part and through '92 I believe the carpet type would be consistent. It also wouldn't be much of an effort to dye what you do have. If you're unhappy with the results you know what the alternative is. The choice of dye could be important.
Old 06-25-2013   #3
it is not too bad to pull off and can be done in one piece, you just need to take your time. I have done it now to a few dash pads without damaging the dash pad, might have damaged the carpet though
Dying it may or may not work as you want it to..
Old 06-25-2013   #4
RICHARD TILL
try spraying it with light coats of vinyl dye and then rubbing it in. it`ll work. a rubber glove is recommended.
