Old 06-04-2013   #11
vilant
Default Re: Looking for ECC info
Thanks fellas, the list now has 2 more,
16 Coolant Temperature In degrees C
17 Solar Correction 114 = Max light 128 = max dark
still missing 19-24 though. It's been rebooted before the light started flashing (had the battery disconnected a couple of times a month ago).
Joe
1990 Bright Red ZR-1 #2599
Old 06-05-2013   #12
Starman
Starman's Avatar
Look at my note under the "A/C Went Out" thread. My LED was blinking and I never could pull any fault codes out. You may want to carefully remove and disassemble the EEC and replace the large capacitor at the rear of the board where the wiring harness connects - same great quality as those in the Bose amps. Also look for cold solder joints on the PCB and re-solder as indicated.
Old 06-05-2013   #13
vilant
Thanks, if recharging the refrigerant doesn't correct it, I'll look into that, everything seems to be working correctly though (I was able to pull the code).
Joe
