![]() Join Date: Apr 2012
Pickup up this R-D Camber Brace a few months ago. Finally completed coilover and sway bars installs and now ready to install camber brace before getting an alignment, but having a little trouble figuring out how this brace is installed. Do I have all the parts needed for install? Anyone have good pics of brace to help? Thanks in advance for any info
I have one installed. Stand bye while I get a pic.
Left Side (drivers side):
![]() Right side (Pax side) looking down at it: ![]() Crossbar running underneath front of the air horn. Tight fight: ![]() Mine is an early one I think 10+ yrs old. Yours may not be exactly the same. As I remember the DS crossbar-to-short-cornerpiece bolt was a bi-atch to tighten due to limited access with the tools I had then. On the plus side, it works great once you get it installed! Good luck |
Thanks for the quick reply and pics. Best pics I have seen of one installed, there are tons of pics for L98 and LT1 cars but not so much for the Z. I will hopefully have time tonight to take a look and try to install. Thanks again
![]() Join Date: Jan 2004
Tony Davila (Projects) Water Meth: http://www.zr1.net/forum/showthread.php?t=19422 Exhaust cut outs: http://www.zr1.net/forum/showthread.php?t=22689 Auxiliary 12V install: http://www.zr1.net/forum/showthread.php?t=22878 Auxiliary pusher fan install: http://www.zr1.net/forum/showthread.php?t=22859 Oil Catch can Project: http://www.zr1.net/forum/showthread.php?t=20320 |
![]() Join Date: Jan 2012
What coil overs and sways did you go with? Have heard people talk about c/o's on their Z's but haven't heard much about sways. On my old C5 I went with a c/o system from Pfadt racing and put larger sways from the C6Z51 system. Might be something I do on my 94 down the road. Thanks!
Jim Zorgias ![]() 1994 ZR-1 Admiral Blue/Black #245 1996 Callaway Supernatural 450 1990 Callaway Supernatural 490 / CR-1 #7 |
#7 | |
-CJ |
#8 | |
![]() Join Date: Aug 2009
Cool pics. I need to install mine... one day
1990 ZR-1 #642 |
