Old 05-24-2013   #21
LancePearson
LancePearson's Avatar
Default Re: My New-To-Me 94 ZR-1
Originally Posted by USAFPILOT View Post
i dont hit 90 in second gear in mine, unless the speedo is off...the rev limiter hits at about 84.
You might have different tires (diameter in actual fact), run at different tire pressures or a different rear end...As far as I know mine has just been rechipped and has a Borlas catback system for exhaust, k and n air intake and the silicone hoses on intake, et al. The chip changes the mixture and the timing both of which tend to increase power.
I haven't tested mine on a chassis dyno but it runs with its stock rear end, 3:45?, far faster than my Ls2 at 415 hp with a 4:10 rear end for punch so mine isn't truly stock but somewhere just above that but way less than ported and relieved, cammed, etc. I lust to drive an FBI or Haibeck or LPE someday or just ride in one that's 600 hp at the crank or more. There will be some of those at the 1/2 drags in Chicago in early June and it will be fun to see their results.
I just know it's fun. let the engine tell you when to shift.....mine is just what I do when I am flat out with it and about 7,000 rpm...I think the rev limiter is 7200 or so but can't remember exact numbers. I don't have a shift light but if I ran drag strips I would.
Lance
LancePearson is offline   Reply With Quote
Old 05-26-2013   #22
HADI-ZR1
One word to say'
GREAT
HADI-ZR1 is offline   Reply With Quote
Old 05-27-2013   #23
Vetman
Vetman's Avatar
awesome color. I could just set that in my living room! Course my wife might say it clashes with our brown furniture.
1990 Z # 2441
1959 c-1 230 HP 4 speed frost blue/silver 3 owner
2011 cts-v 556 HP, manual 6 speed
1955 chev 2dr ht PP 265 3 speed w/OD
Vetman is offline   Reply With Quote
