Old 05-07-2013   #1
vilant
Default Re: LT5 PS pump pressure?
I looked through the 90 FSM, there's a PS test procedure. It says when the engine is up to operating temp. test with a pressure gauge, open the valve and pressure should not exceed 150psi. If it does, it says check for blockages. Don't know if that helps, could post a pic of the page if you want.
