#31 | |||||||
![]() Join Date: Jan 2009
The second paragraph introduces a separate suggestion (topic) and does not imply fuel or Open Loop. Quote:
I see Quote:
I'd agree with your assessment of O2 sensor if it's Open Loop only. I wonder though if it really is open loop only? Still the the reported issue goes away in 10 sec. Sounds like he needs to try a different chip (of any kind) to see what happens in that first 10 sec. Grabbing and using the most obvious symptom like the 10sec one seems wise. The goal is to help get the car fixed. A step by step "what to try next" is in order. I'd say the next step has to be gather more info/symptoms. Possibly attach a data logger if possible.
#32 |
![]() Join Date: May 2005
Having chased DIS problems/differences for 2 years in getting Queenie running I can try to add some notes that helped me. A DIS module has 2 modes, under 400 rpm and over 400 rpm. Under 400 it runs on an internal logic ckt then transitions to the ecm control ckt. If you use a dis checker you can see on a scope the breakdown of the DIS if that is the problem. The car does not run when using this tester. I like to put a plug in each wire and lay them on the plenum. This does 2 things, it allows you to see the rhythm or lack of it. It also allows you to see if a specific plug has a weak spark.
http://thepandatrap.com/tyler/prototype1/90_ign_mod.jpg http://thepandatrap.com/tyler/prototype1/page09.jpg http://thepandatrap.com/tyler/prototype1/page11.jpg http://thepandatrap.com/tyler/prototype1/page12.jpg http://thepandatrap.com/tyler/prototype1/page13.jpg http://thepandatrap.com/tyler/prototype1/page14.jpg http://thepandatrap.com/tyler/prototype1/page15.jpg http://thepandatrap.com/tyler/prototype1/page16.jpg http://thepandatrap.com/tyler/prototype1/page17.jpg http://thepandatrap.com/tyler/prototype1/page18.jpg http://thepandatrap.com/tyler/prototype1/page19.jpg http://thepandatrap.com/tyler/prototype1/page20.jpg http://thepandatrap.com/tyler/prototype1/page21a.jpg http://thepandatrap.com/tyler/prototype1/page22.jpg http://thepandatrap.com/tyler/prototype1/page23.jpg http://thepandatrap.com/tyler/prototype1/page24.jpg http://thepandatrap.com/tyler/prototype1/page25.jpg http://thepandatrap.com/tyler/prototype1/page25b.jpg http://thepandatrap.com/tyler/prototype1/page26.jpg http://thepandatrap.com/tyler/prototype1/page27a.jpg http://thepandatrap.com/tyler/prototype1/page28.jpg http://thepandatrap.com/tyler/prototype1/page29b.jpg http://thepandatrap.com/tyler/prototype1/page30.jpg Not sure you have the above for reference. I will be at Britts next week moving Queenie from Detroit to the NCM for display and will have the checker with me. The advantage of this is you can run the complete DIS ckts with the plenum off the car and watch the signals on a hand held scope. I tend to think the problem is not with the dis rather a leaking injector. I would start the car for about 5 sec and turn it off and pull the plugs looking for 1 that is wet/damp. You can then chase the spark or fuel delivery of the actual offending cyl. Tyler |
#33 |
![]() Join Date: Mar 2007
I did check the injectors when I pulled the plenum to replace the starter; not leaking under pressure, will pull the plugs and check
#34 |
We can rule out ECM, swapped the ECM from my 91....same symptoms, will run it with a different chip today. I did run it with a different chip for a 368 w/ intake cams. I did not take it on the road, just around the neighborhood. It did seem to struggle after a few minutes and die(same symptoms as before).....but I want to test it under the same conditions and make sure it is apples to apples. The sputter and stall happened as I was backing...so hard to rule out tune at this point
#35 | |
#36 |
swapped the eprom, same result....althought keep in mind maybe this one could have the same issue?
91 Vette Drs 368 with large intake cam, stock exhasut
#37 | |
His car would drive for 10 minutes and cut out / die consistently Replaced the pumps / clips and issue was fixed Not sure if this is our issue but thought I would pass along what I saw ![]() David |
#38 |
Lee,
A 90 won't run very well w an EPROM using a 91 calibration. Must be same BCC for that year car. Now it will run in any year ECM however. One other issue w the 90 prom is the knock filter on board later year chips while 90 is external. |
#39 |
Surprising although the motor was less responsive....idle and driving were normal
#40 |
Got a code 64 finally I think that confirms its the 02; lean right
