Old 04-03-2013   #61
Default Re: ZF-6 oil
is this the AMSOIL some of you have been using?
http://www.amsoil.com/lit/databulletins/g2080.pdf
it does list GM 1052931 on the PDF
http://www.amsoil.com/shop/by-produc...n-fluid-5w-30/
Old 04-03-2013   #62
dredgeguy
dredgeguy's Avatar
Got the Castrol 10W-60 at the BMW dealer...painless
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 04-03-2013   #63
alwayscode390
So, the Castrol is the proven stuff ... the only issue is the low mileage maintenance requirements?
Whats some good stuff to use with higher mileage maintenance intervals? ---
[SIGPIC][/SIGPIC]
01' Dodge Viper GTS
11' Ford Raptor
90' ZR-1 Corvette LPE #699
Old 04-03-2013   #64
WVZR-1
I noticed that maybe a week ago or so and I hadn't seen it in earlier. That .pdf is dated 7/12 and maybe it's actually just found it's way to the Internet and the previous versions didn't mention it. They actually only mention it by part # and there's no mention of the ZF S6-40 anywhere in the description. The GM applications mentioned are assemblies that always called for Synchromesh.
The only issue I've ever had with the MTF or any Amsoil product was the "shove" provided by most of the re-sellers. The implications of "by from me for 20% off and all that nonsense" is ridiculous. Check the other forum and it's generally "game on" to see who can post to an appropriate thread for any lubricant first.
I've plenty of the 1052931 and with the availability of other products I doubt I'd ever become an MTF user.
Why would you think the trans requires some "super extended higher mileage" intervals? It's less than 3 quarts of product. I wouldn't think the effort or the $$'s would create an issue for most!
Old 04-03-2013   #65
Yeah I too did not care for the AMSOIL push by some vendors at shows etc..
I did end up signing up for a preferred account on my own and I can pick up locally which is nice so then I can just get the Trans oil when I get my motor oil..
I did email Bill B regarding AMSOIl Synchromesh and this was his response:
Originally Posted by ZFDoc
AMSOIL Synchromesh oil is great oil to use in the ZF S6-40 transmission.
Old 04-03-2013   #66
alwayscode390
Arrow Re: ZF-6 oil
I don't think it requires that ... I just thought I read that using the Castrol required twice the maintenance than the factory scheduled maintenance intervals. Not that big of deal I guess , I don't put many miles on mine anyway ---
[SIGPIC][/SIGPIC]
01' Dodge Viper GTS
11' Ford Raptor
Old 04-03-2013   #67
I think what Bill Boudreau was saying zfdoc questions and answeres is that any ZF S6 40 transmission oil should be changed at around 10,000 - 12,000 miles
Bill suggested........."until someone invents a copper magnet, we recommend that the ZF S6-40 6-speed transmission oil be changed at 10,000 - 12,000 mile intervals so as to minimize the amount of deposits of the suspended spent synchronizer material from collecting in critical component contact surface areas".
Old 04-03-2013   #68
alwayscode390
OH, ok ... so that's a recommendation no matter what with our transmissions. Thanks ---
[SIGPIC][/SIGPIC]
01' Dodge Viper GTS
11' Ford Raptor
Old 04-03-2013   #69
mike100
Yes.
Old 04-03-2013   #70
efnfast
Yes
