03-31-2013 | #1 |
90 Accessory Plug???
I didn't want to steal a previous thread but did spark a question. I have been told my 91 owners that there is an accessory plug under the console. Did the 90's have one as well? I have had my console apart several times but never seen one.
Rich
03-31-2013 | #2 |
Re: 90 Accessory Plug???
There's no mention of one in the '90 FSM or owner's manual. I assume an accessory plug is a 12V outlet like the cigarette lighter, for plugging in something like a radar detector or other 12V device?
Joe 1990 Bright Red ZR-1 #2599 |
03-31-2013 | #3 |
Rich,
I think IIRC, the accessory plug started in 1991, found mine on my 91 ZR-1 behind the FX ride control switch with a piece of electrical tape covering the connector. On my 91 L98 car, I used that same accessory plug to power my bolsters and electric seat tilt function on my 90 sport seats I just installed in it. It is a switched connector so it will only power up with the key on. Jeff |
03-31-2013 | #4 |
No only 91 and GM put it there for one reason. As a power tie in for your brick cellphone
