Old 02-22-2013   #1
zrwhat
zrwhat's Avatar
Default Power Seat Tracks
Anybody have a line on repairing non-working seat tracks for 90-96?
Picked up a pair of seats from a low mileage 90 wrecked parts car here on the registry and just got around ti doing the install and low and behold they skip going both forward and backward so they are completely inoperative at this point.
Anybody have a line on replacements?
I see Keen Corvette rebuilds them at $100 a pop, looking for options...
Thanks folks,
Gibby
zrwhat is offline   Reply With Quote
Old 02-22-2013   #2
VetteVet
VetteVet's Avatar
Default Re: Power Seat Tracks
I purchased rebuilt tracks from Keen and have had no problems. I believe that they are having the needed parts reproduced themselves, as I could not find any other source of repair or parts available, ANYWHERE, at the time that I was doing the research.
VetteVet is offline   Reply With Quote
Old 02-23-2013   #3
Perhaps this might help.
http://www.youtube.com/watch?v=vkherEznB08
If they are skipping it may be the transmission.Not cheap but may save cost and hassle of shipping.
http://www.vette2vette.com/finder/parts
Old 02-24-2013   #4
zrwhat
zrwhat's Avatar
Thanks Yun,
I just pulled it apart and the plastic housing inside the seat transmission enclosure is cracked allowing the seat slider fore and aft to skip over the nylon gear and not move.
Found Keen Parts rebuilds them for 100 bux, looks like I'll go that route.
Sad part is both sides arrived DOA on the seats they were bolted to, they came from a 27K mile 90 ZR-1 and the seat frames are nice looking and but for a few small marks on the drivers seat, seats truly look like they are from a low mileage car.
I'll let you know how it turns out.
Gibby (tow guy)
Old 02-24-2013   #5
Originally Posted by zrwhat View Post
Thanks Yun,
Gibby (tow guy)
What color are the seats? If black, real easy to touch up.
Old 02-24-2013   #6
Jagdpanzer
Jagdpanzer's Avatar
Gibby
At this stage more than anything age is what does in the plastic components of the seat transmissions. Same thing happened to my driver side seat transmission a couple of years back and I went with a Keen replacement with new plastic guts.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 02-24-2013   #7
zrwhat
zrwhat's Avatar
RED
Old 02-24-2013   #8
zrwhat
zrwhat's Avatar
Gibby
I'm sure since the car was involved in a hard hit that didn't help much, jarring and the shock of impact more then likely helped the tracks to the end of their journey, seller said they worked, I plugged them in and one side did nothing but skip on the gears, other side moved about a inch and that was all she wrote, went right into the gear skipping noise and I stopped there to prevent any further damage.
Gonna pull the second seat trans out and see if enough items can be swapped out to make 1 work and use that one for the passenger side which can stay in one position or I can save some weight and put a manual slider on that side.
Thanks Phil,
Gibby
