Old 03-05-2007   #1
moesvette
moesvette's Avatar
Default Flashing SYS light???
I went to start my 90 the other day, and battery was too low........charged it and it is holding fine, but I have a flashing SYS light, which I assume is from the low battery charge. I figured once the charge came up the light would stop......do I need to do something else? It seems to run fine, other than the flashing SYS. I did not clean the terminals......maybe the problem?
Thanks as always for any help.
1990 Red/Tan Mark Haibeck Chip/B & B
moesvette is offline   Reply With Quote
Old 03-05-2007   #2
Peaven
Peaven's Avatar
Default Re: Flashing SYS light???
You probably want to check the cables to make sure they're tight and check for corrosion around the battery posts as well...also might try disconnecting the negative cable for a bit, that may clear a flashing SYS error. Other than that, it may just be a weak battery...one other thing, drive it a few times before you give up on the battery. I seem to remember that it may take 3 or so on/off cycles to reset the SYS message.
Wichita, eh? That's where i picked up my blue `94 last year...WydglydJim over on cf is also from Wichita, he has a blue `90...
Peaven is offline   Reply With Quote
Old 03-05-2007   #3
Jeffvette
Follow the procedure in the service manual to access the codes in the CCM and go from there. Sometimes it will take a while for the SYS light to go out on a car that hasn't been driven in a while. It took about 90 miles to happen on a car I"m currently working on.
Old 03-05-2007   #4
moesvette
moesvette's Avatar
Thanks guys. Will double check condition of the terminals........new battery last year, so hopefully okay. Yea, Wichita.......we call it Doo Dah! Have run into the other Blue ZR-1 at a couple local shows, and have another member in our Southwinds Corvette Club that bought a 90 Quasar Blue last year. Several of us around locally.
Looking to change out Injectors this year. Is RC engineering still the injector of choice?
Old 03-05-2007   #5
tccrab
tccrab's Avatar
I put a set of Accel injectors in my '90 last fall, can't be happier. Both performance and price wise. Accels cost about half as much as the RC's.
TomC
'90ZR1 #792
