Old 02-18-2013   #21
VetteVet
VetteVet's Avatar
Default Re: Anyone care to guess...
Originally Posted by Blue Flame Restorations View Post
Jep, just stay away form the French models! LOL
You didn't say anything about the French model's girlfriend, though. HEHEHE
VetteVet is offline   Reply With Quote
Old 02-18-2013   #22
That commercial cracks me up everytime I see that smirk on the French Model's face.
Jep, that project sounds promising. Excellent R&D!!
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 02-18-2013   #23
VetteVet
VetteVet's Avatar
Jep,
Very cool. What are they off of? GM? Am I looking at 3 or 4 pins?
Dom,
They are not GM. They are from a high horsepower, high revving 5.3L V8. I'm not going to say any more at this time.
They are 3 pins. BAT+, GND and trigger. Trigger high to start dwell period, trigger low to cut primary current and fire the coil. I have a scope so I can get data on dwell as installed in the OEM application. This data can be used to populate the cells in the LS1 PCM coil dwell table.
Jep
Old 02-18-2013   #24
This will be quite cool.. especially if it works with the CCM
Old 02-18-2013   #25
Originally Posted by VetteVet View Post
Dom,
Jep
Part of the issue w the LT 5 ignition module and LS coils. No way to modify dwell. The LS coils use 4 wires w +, power ground, ECM ground, and trigger.
Old 02-18-2013   #26
VetteVet
VetteVet's Avatar
Dom,
I can understand that, since dwell is entirely controlled by the ICM. The dwell tables in the LS1 PCM will allow folks to choose what coils they want and tailor the PCM to properly trigger them as long as:
a) the coils have built in driver circuits (smart coils) or external driver circuits are used and
b) the coils or external driver circuits use a TTL level trigger.
I know that you and others here understand this, I'm just spelling it out for the benefit of others who are reading.
Don't hold me to this, but my intent is to have my car in BG running on the 411 PCM with full cluster, cruise, etc. functionality with secondaries deleted and COP pencil coils installed. I may or may not achieve that goal. We'll see.
Assuming that all of that goes well, I will begin work on a solution that integrates full secondary functionality. That will take more time, though, as it will probably involve modification of the PCM code.
Jep
Old 02-28-2013   #27
how is this progressing?
Old 02-28-2013   #28
cvette98pacecar
It looks like I may have sourced the COP ignition coils. They are a very good fit. The ridged seal is a snug fit in the spark plug hole and the length is almost right on the money. They are smart coils, so there should be no problem controlling them with the LS1 PCM.
I'm going to pick one up(I borrowed this one) and verify that the PCM can control it.
Jep
Jep, Got an add on for you. Anyone out there want to make up a CNC aluminum din rail to hide the wiring? Could be held down by cam cover bolts. This could be fully customized with any logo added to the top.
Old 02-28-2013   #29
VetteVet
VetteVet's Avatar
Robert,
I've already ordered and received the 6061 aluminum bar stock to do this. I will have to do the first set manually on a friend's milling table, but once I get the fit(notice that I din't use "fitment") worked out, I will produce a cad file for reproduction.
Jep
Old 02-28-2013   #30
VetteVet
VetteVet's Avatar
Jeff,
1) I'm finishing up the wiring harness mods.
2) I have ordered and received one of the COP coils pictured previously to be used for testing.
3) Today I received my EFILive FlashScan V2 and software to load up the base tune and for follow-on tuning.
4) As stated in my previous post, I have the aluminum bar stock to machine the billet coil/wiring covers(rails).
5) I have received the stock needed to machine the crankshaft reluctor mount. I still need to obtain the stock for the sensor mount.
6) I have started working on the base tune to get the car up and running.
7) I'm still waiting on a benchtop programming harness(to load tunes onto PCMs while removed from the car) and flanged Deutsch connectors to attach the coil rails to the coil harnesses.
8) I think I've found a suitable PCM bracket, but haven't ordered it yet.
To all,
Keep your eyes on the For Sale section. I will be posting some stock parts up within the next few days. All profits from these sales will be dedicated to funding this project.
Thanks for your interest and support,
Jep
