Old 02-06-2013   #31
Corbusa
Default Re: SS Braided Oil Cooler Line
Dang ! Thats SWEET !!!!!!!!!! You guys are killing me with all the add-ons .. ssheezzz. shifters, leds interiors, exhaust, stainless air cleaners, bla bla bla bla . I cant work enough.. I'll have to catch you later on this one , maybe keep me one on the shelf.
Old 02-06-2013   #32
Originally Posted by cvette98pacecar View Post
Damm I need to sell one of these cars.
First in line on the 91 CAB. Like that one will ever go lol. D
Old 02-06-2013   #33
efnfast
Yeah, I'll second that.
Old 02-13-2013   #34
Guys,
Parts have been ordered and should go into production sometime next week.
Old 02-13-2013   #35
94Admiral
Excellent! Can hardly wait.
94Admiral is offline   Reply With Quote
Old 02-14-2013   #36
Default Oil Cooler Adapter
Are you sure those two fittings are not 10 AN/M18x1.5 ?
Aluminum plate was Cadded using factory piece then modified to accept M16X1.5 fitting to accept AN 10 fitting. Then the pieces were black anodized.
Old 02-14-2013   #37
Thsy are M16x1.5s. I bought a few already.
Old 02-21-2013   #38
Update - Parts arrived yesterday. Fabrication will be done on Monday or Tuesday and shipped the next day.
Stay tuned.
Old 02-21-2013   #39
1. Use two 10 AN Stainless Steel Braided hose.
2. Use two AQP Hose, 90 Degree, -10 AN Hose to Female -10 AN, Aluminum, Nickel Plated.
3. Use two AQP Hose, 45 Degree, -10 AN Hose to Female -10 AN, Aluminum, Nickel Plated.
4. Use two 10 AN M18x1.5 fittings threaded into the Aluminum adapter manifold with "0"rings.
5. One 6mm x 1.0 x 35 mm SS Allen head bolt.
6. One 6 mm SS washer.
7. Two "O" rings for the Aluminum adapter manifold to oil cooler interface.
The first four items can be found at Summit Racing.
Dynomite,
May be it was M18... My memory isn't what it use to be. If so, I'll have to return and order new.
Did I send you that pic?
Old 02-22-2013   #40
I took the picture of my own hose fabrication
Without checking I got M16 from Summit Racing including the Aeroquip fittings. I ended up with M18x1.5.
I did not want to INSIST on that M16/M18 issue as I sometimes am wrong even though I am positive I am right.
By the way...that is why I post technical stuff so often.....as a sanity check and confirmation. I figure if no one says anything I must be correct
Appreciate that Black ZR-1 flange....excellent work
I use a Small Angle Grinder for cutting the SS Braided Hose which does not fray the SS braids on the hose ends. I also use an appropriate size Box Wrench on the Hose Fittings (box end) to minimize leaving marks on the fittings.
Note:
Unless you are making up several SS hoses it is much cheaper to just let someone else do it like secondchance (there are some tricks)
Dynomite,
You are correct - fittings I need are M18x1.5-10AN and not M16. I am exchanging messages with the seller (in Hong Kong) so that I can bring the correct ones and not get stuck w/ $150 dollars woth fittings I have no use for.
I use a scissor cutter meant for braided line - sotrta looks like a bolt cutter. I tried using a hack saw at first and learned a hard way.
