![]() Join Date: Jun 2012
So I just got the software for my new car scanner (turns your laptop into a scanner). It's got a ton of features, but I can't wait to test the built in dyno and accerlation tests it has.
I sense some cold air intake tests in the near future ![]() Last edited by vilant; 01-16-2013 at 03:21 PM. Reason: typo |
Joe how much was the software? Does it data log as well? Does it run in a Windows 7 environment? GC
#3 | |
![]() Last edited by vilant; 01-16-2013 at 03:27 PM. Reason: typo again |
Oh and yes it works on several platforms, Windows XP, Vista, 7 and 8. I haven't tried the data logging but it does have it. I really haven't had a chance to play with it yet. Only reset some lights on my pick-up.
![]() Join Date: Sep 2012
Which scanner are you using for this software?
Gotcha. I thought you used a stand alone scanner plugged into your laptop and then this is the software for it. If I'd read your first post correctly you explained it pretty well.
![]() Join Date: Jul 2007
do you have a link for more info.. Searching Total Car Diagnostics.. shows info but say for OBD 1 only Corvette (16 Pin) ALDL is supported I am quite sure my 1990 is 12 pin
#10 |
![]() Join Date: Jan 2009
On a related note, here is a forum of interest for scantools.
https://www.scantool.net/forum/index...itisirn9d4la7&
