#51 |
![]() Join Date: Dec 2003
HADI HAS THE RED LIGHT ON AT HIZ HOUSE THOUGH!
TILL ROCKSANNE MOVED IN AND TURNED IT OFF!!! LOL Last edited by WB9MCW; 02-13-2007 at 10:58 PM. |
#52 |
AW i guess poor hopalong is going to be getting the gas for a while. But he seems to be a good sport. Also was nice enough to give us a great sounding video. how do you speed shift with that cast . horefully no holes in the fire wall
#53 |
![]() Join Date: Aug 2005
This thread has been very interesting.
The stock rev limiter is set to 7072 rpm. It is set there to preserve the life of the water pump, alternator and steering pump. The engine's redline is 8000 rpm. Above that rpm you risk valve float, although a few members have run their motors above 8000 rpms without issue. Will it hurt to hit the rev limiter? No. Will it hurt to hit the rev limiter many times? No. Will it damage the engine to run it on the limiter all day? Well - that can't be good for the cam chains or the cams themselves, but the rest of the engine won't give a damn. Moral of the story - don't worry about touching the rev limiter from time to time. Mine is set to 7400 rpm with a 4.125 inch stroke, which is the same piston speed as running a stock motor above 8000 rpm. I also have larger pulleys on the water pump and alternator to slow them down, use less power and extend their life as I wring it up to 7400 rpm on a regular basis. As for shift lights - set them 200 rpm below where you have the limiter - shift just after you see the light, and you'll never hit the limiter. ![]() The stock shift light is too difficult to see to be useful. It was calibrated for peak power on the stock calibration when at WOT, and for fuel economy at part throttle. It was pretty cool. |
#54 |
good info---nice to see ya postin here doc---hope u are happy in yankee land now---
#55 | |
![]() Join Date: Dec 2004
#56 |
![]() Join Date: Jul 2005
Curtis:
I always enjoyed it when I heard of something else No 364 had done or was about to do. Always was courious what would have happend next if 364 wasen't wrecked. Jan |
#57 | |
There were two things that I wanted to do with #364: 200 mph and 10 sec 1/4 mile. I did one and will always believe that I would have done the other on Sat. at BG when #364 was wrecked. Now had I accomplished both goals, I probably would have raised the bar but will never know. 11.08@129 will just have to suffice. Curtis |
#58 |
wow that a great et and mph . what mods did you have to get there? what did you do to the suspension to get it to hook up? love to learn from ya. thanx
#59 | |
#60 |
It's north of 7500, I know that!
