Old 01-06-2013   #1
mgg
Default Re: GB: DRM Coilovers
Well. I know it has been awhile since this all got started but I was able get all of the coilovers mounted on saturday. Now I have to say that there are some challenges taking out the front spring and I am glad it is done. Something I would not look forward to doing again. One thing many might find interesting. I had removed the front spring once before to install the poly shims that are available through Mid America/ Ecklers along with the lowering bolts. The poor mans suspension adjustment setup. When I removed the front spring this time, I had found that the poly lowering wedges were absolutely destroyed. There was nothing left. That is after about 1500 miles of pretty easy driving. So in other words, that stuff is JUNK. The coilovers are on and this morning spent some time adjust the front ride height. Getting close. I'm burnt out now so the rear will have to wait for a day or two. The service ride control light is now on so I will also have to look into that. When I am finished, I plan on putting together some do'd and don'ts for the this coilover install and hopefully it will make anyone who wants to do this conversion aware of certain issues that can be avoided for an easier install. Thanks for everyones help on the forum who responded to my many questions. Pictures will follow one day.
mgg is offline   Reply With Quote
Old 01-06-2013   #2
Good job and congratulations!!! I am sure you feel jubillant that it's done and over with.
Old 01-06-2013   #3
HAWAIIZR-1's Avatar
Good to hearing things are heading in a positive direction. I'm glad I never tried to install the wedge/bolts to lower.
What are your and the group's thought about non FX3 if going coilovers and just get rid of the FX3?
I don't know if any installation benefit or just avoiding future problems and cost.
Thanks for sharing.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 01-06-2013   #4
Thanks for sharing.
Craig,
I am seriously thinking about going coil-over come spring. I intend to keep FX3, if anything, to keep the SRC switch working.
If I elect to discard the system later that can be done regardless.
In 18 years of ZR-1s, 1991-1996 and 2000-2013, FX3 functioned 98% of the time without any issues. So, why discard it?
Old 01-06-2013   #5
Thanks for sharing.
Craig,
Keep FX3 definetly! Keep your ride quality.
I've driven another Z with Morocco shocks and make the car even "tighter".... (though expensive)
Old 01-06-2013   #6
Keep the FX-3 works great with it
Old 01-06-2013   #7
mgg
I would have to agree with the others who suggested retaining FX3. As long as the car is going to be street driven I would stay with this setup. I do suggest that you carefully think about what spring rates you want to run though. If the car is street driven I would go no higher than 425 front & 300 rear MAX. Randy talked me into 250 rear and I think that will be a good choice. YOu might even consider less if it is a later model car whoose springs were a tad softer than the early. NOthing would be more disapointing that being unhappy with too stiff of springs. So far in my short amount of driving ( just settling ride height) the car feels great. I hope my resolution to FX3 problem is quick as I have never had this issue before the install. I have to say that the squirly side of me justs LOVES the stance of the front now. It looks serious. Now I need to spend the same amount of time on the rear and then off to the alignment shop. Its funny I don't know if I am more happy or releived that this is done. It does give one a good sense of accomplishment though. I very lucky to have some good friends who really helped me out.
Old 02-08-2013   #8
HAWAIIZR-1's Avatar
Mike,
Your setup looks great with the photo that Bob posted and that is kind of what I am after in terms of looks, ride, and handling. My setup came in the last week, but I was out of country and finally looked at them today. I got the whole deal with trailing arm and camber brackets; everything looks great and well packed for shipment. The front rates are 425 and the rear 250 so Randy felt the same based on what I was looking for. Here are his thoughts: 300 too stiff, 275 right on, 250 a tick softer than the 275. I'm waiting on Carter brackets and in the meanwhile I need to figure out how I will have the shocks grooved. Thanks for sharing your info and experience with this setup.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 02-08-2013   #9
Craig I wholeheartedly agree.
http://www.zr1.net/forum/showthread....ight=coilovers
As you can see above I went with the hypercoil 425/275 spring rate as well which is the right rate for our car. Any stiffer on the back end and you will feel like you are riding on a buckboard
After the install im sure your impression will be the same as mine that this was the way the car should have been setup from the factory. In turns she will ride like on a rail.
