Old 11-25-2012   #1
CJ_ZR1
Default Winter Project (Phase 1)
Well I guess you can call it a winter"ish" project due to the fact that here in Louisiana we get to drive our cars year around. This project started at the end of August and on the drive to garage where the project would be performed, she rolled 56k miles.
Phase 1:
Powder coating engine
FIC SS injectors
Stainless bolts
Secondaries removed
Charcoal system removed
Top end gasket set from Jerry's
Chip tune by Pete
And can't forget lots of cleaning
Engine before pic:
Let the tear down begin...
The pile of parts is growing...
CJ_ZR1 is offline   Reply With Quote
Old 11-25-2012   #2
CJ_ZR1
Default Re: Winter Project (Phase 1)
Secondary removal:
Pulling the butterfly shaft wasn't too bad once we cut a piece of metal pipe to about 1.5"; and used a nut, washer, and socket to pry the bearing out.
Freeze plug where butterfly shaft was located
Old 11-25-2012   #3
CJ_ZR1
While waiting for engine parts to return from powder coating, we had a chance to clean whole front end of the car.
Parts have arrived!
Had the stainless steel air box powder coated to match...
Old 11-25-2012   #4
CJ_ZR1
Phase 1 complete!
It took about 6 weeks from tear down to first start up. We changed oil and went for drive about 3 am Saturday morning, sleep 2 hrs and then headed to car show an hour away in Lafayette, LA. My Z ended up being selected 2nd in C4 category, 1st being a red/red 96 lt4 car (he had car super clean).
Group of 4 that drove down for show.
It was a long project but well worth it.
Many thanks to Daniel Mcguffee, Pete, Jerry at http://jerrysgaskets.com/ and Mike at http://www.thepowdercoater.com/
Phase 2 should be starting before Christmas:
DRM Coilovers
32mm front and 26 mm rear sway bars
R&D frame brace
Old 11-25-2012   #5
Blue Flame Restorations
CJ, congrats on a job well done! Daniel is a great guy to have help, but you already knew that!
Can't beat Pete and Jerry. So many great people on the forum. Great to see the Brotherhood in action.
Beautiful Z, BTW.
Brett
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 11-26-2012   #6
2ZR1S
2ZR1S's Avatar
CJ, man it looks good. Keep the pictures coming as the work progresses.
Thanks
Jon R
Jon R. Member #490
1992 ZR-1 Arctic White/Red
2008 Z51 Silver 6 spd (Daily driver)
2ZR1S is offline   Reply With Quote
Old 11-26-2012   #7
carter200
carter200's Avatar
Originally Posted by CJ_ZR1 View Post
Phase 1 complete!
CJ,
You need a little CT Machining bling on that bad boy. Throttle body plates are in stock and coolant pipes can be a one day turnaround along with what ever else you want that I make or your imagination can produce. Nice looking job you did, Carter
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 11-26-2012   #8
Fully Vetted
Fully Vetted's Avatar
"Throttle Body Plates"...Do you mean the cover?
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 11-26-2012   #9
vilant
Looks great. Nice job.
Old 11-26-2012   #10
VetteVet
VetteVet's Avatar
CJ,
Your car is coming along nicely!
I've got to make plans to get together with you and Daniel.
Jep
VetteVet is offline   Reply With Quote
