#41 |
![]() Join Date: Nov 2011
It just seems there are so many interpritations of hp.
With and without headers or exhaust. Same for intake. Air quality. What day of the week it was, ect,ect. |
#42 | |
![]() Join Date: Jun 2005
Seems I was wrong about the early engines...375 SAE net and 415-hp (rather than 425) gross seems to be the case. The SAE net is SAE J1349. I've heard of the other test, but never knew what the GM designation was nor do I know the correction, but I'd say you're right on 77°F. It wouldn't make sense that GM would use two different atmospheric corrections.
#43 | |
![]() Join Date: Jan 2009
![]() HP #s are great talking points but ETs are better ![]()
#44 | |
![]() The numbers are meaningless to those that do not understand the numbers or the "manipulations" of the numbers (the math) ![]() Most designs that I know start with manipulations of numbers (math) of some sort. And we (some of us) can get pretty close to the end result where the rubber meets the pavement with the math ![]() The GM Engineers did not design the engine and drive train by running ETs (trial and error) I would guess. They did the math ![]()
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 11-24-2012 at 02:22 PM. |
#45 | ||
There are many factors which skew chassis dyno numbers but have nothing to do with engine performance. In no particular order, some of them are: 1) tires...casing design, tread configuration and tread compounding. (I once did a back-to-back test of two tires just comparing tread confiuration and compounding-the tires were both on the same casing design-and the differece was 5-hp at the wheels. Same dyno, same pressure, same vehicle, some IAT and ECT, and tests 10-min. apart.) 2) tire pressure 3) dyno type, inertia or brake 4) single roller, two rollers or no rollers (direct connection to axles) 5) roller surface 6) wheel spin or lack thereof 7) trans type 8) trans lubricant and lubricant temperature. 9) rear axle ratio, lubricant and lubricant temperature 10) powertrain mountings 11) coolant temperature and temperature rise during test 12) different in IAT of more than 7°F regardless of correction 13) technique of dyno operator 14) condition of dyno So, you see...chassis dyno numbers should be taken with a "grain of salt". They are embraced by the aftermarket performance industry and the enthusiast community because chassis dynos have been well-marketed by their manufacturers, they're loved by the automotive press and widely used by tuners. Chassis dynos are cheap and easy and perfect for bragging rights but fraught with potential inaccuracies. I'm first to admit to using chassis dyno data all the time. Sometimes I strive to eliminate as many of the potential inaccuracies as possible. Sometimes I don't, but I know in the back of my mind that engine dynamometers are far more accurate devices for comparisons. As for corrections...the belief that atmospheric corrections don't make a difference is just ridiculous. In fact, when I look at chassis dyno data, I'm more concerned with whether or not a correction has been applied and if so, what correction than I am with the inaccuracies of chassis dynos. Recently, I was discussing a particular engine modification package with an aftermarket vendor. I asked for some of his confidential test data and he provided it. Same engine, same dyno, same test run...the engine made 646.0-hp "standard" corrected and 613.9-hp SAE-corrected. See why the aftermarket and braggers like "standard" corrected data rather than SAE-corrected? But, SAE-corrected is much more characteristic of the real world because of its use of 77°F for intake air temperature. Lastly... ETs are either the most inaccurate way to bench mark engines or the most accurate way to benchmark the whole "package"...driver and car. Do drivers are bragging about their engines. The first driver who majorly sucks on the starting line and has crappy tires but has a really good 350 in a ZR1 might go 13.2 The other driver who gets really good 60-foots, has his/her tire configuration just perfect but has a so-so 350, can run a 12.8. So...who's got the best motor? But...who's got the best ET?
#46 | ||
ETs can be the best way to measure overall performance there is. Sure some exceptions can be brought to bear but there's many more exceptions that can be added. Why even the effect of the moons gravity has an effect and the imperfections on the asphalt under the right rear wheel. There could even be a mosquito hit the windshield and slow it down. Same driver running two different cars on the same night could even have different wind conditions, a huge fly hit the windshield plus the major effect of 0.01oz of more fuel in one car vs the other. gezzzzzz Seems like an exercise in futility to me. A huge amount of meaningless exceptions can be added to dyno derived HP numbers too but I won't go there right now. HP numbers are a fine metric but so is how many dimes you have in the change holder. Being able to wave bye bye puts the "P" in performance. It's all together a better metric whether it's SAE or standard or pure air guitar corrected numbers. Quote:
Depends on the quality of the eye looking at it and the ambient air quality that the light goes through. But it should be SAE corrected air quality else it's all for naught. And one should use proper wide spectrum light to test with and of course the angle of reflection should be at 90deg +/- 0.0000001 deg or the error will be so great that all bets are off. ![]() Which is the better car? 1. 10,000 rpm V8 2. 502ci V8 3. 1800lb with driver 4. first over the 1/4 line Answer: depends on which one I'm sitting in and Voltage measured at the spark plug of course. ![]() Any hair that is split can always be split again until it looses meaning.
#47 |
Pretty much why you judge power on basis of trap speed not ET. Trap speeds can vary based on track setup.
#48 |
![]() Join Date: Nov 2007
The trouble with standards, are there's so many to chose from:
J1349 circa 1972, June 1990, 2004 (crank hp) J1995 (gross hp) J607 J2723 certification spec VCA (UK certification spec) And, NONE of these address AVERAGE torque or hp at the wheel! Bottom line: You can measure at the crank, or you can measure at the wheels, or somewhere in between. But, trying to predict one from the perspective of the other is full of variables as to make an absolute prediction either way almost folly. I believe the trick is to pick the one that best fits the application, make the measurements as a base case for comparison to future improvements or modifications. Examples: Engine builders with clients paying for results aren't interested in driveline losses. Drag racers aren't interested in peak hp at the crank, they're interested in trap speed (and ET to a lesser degree). To get J1995 (crank net hp) I have to pull the motor. But, considering inertia of drive line hardware (including rotating mass), the hp number derived is significantly removed from how the car is going to actually perform, at least where differences are subtle. For seat of the pants fun and a more accurate indicator of drag race result prediction, the inertia dyno measuring output at the wheels is a much better fit. However, quarter mile trap speed is a very good indicator for performance comparision! It isn't perfect either, but it does take into consideration "power under the curve" which is largely overlooked when in a pissin match over gross vs. net vs. shaft vs. wheel horsepower ratings. Where the rubber meets the road is where real performance is demonstrated...I think is the main point ... at least it is for me. I'm not saying either isn't important in their own right - engine builders have their point of view and race drivers have a different perspective on output. But, trying to predict either from opposite ends of the drive line (read: is it SAE 15% standard loss or some other 18% standard) is where things get fuzzy really fast. Hib...You said Barney measured 413 at the wheels. You used 18% drive line loss to predict you have about 504 net hp at the crank. My 90 Z measured 432 hp at the wheels, using SAE/Marc's 15% drive line loss, my net crank calcs to be 508 hp. Now, going on net crank hp and nothing else, I imagine it would be a near toss-up in the quarter mile, all things being equal. Care to race and compare?? P. |
#49 |
![]() Join Date: Sep 2012
#50 |
I doubt you would want to race with me
![]() I did the MATH ![]() Cliff The 500 hp LT5 Rebuild 1991 ZR-1 (LT5) Performance
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 11-26-2012 at 06:46 AM. |
