Old 11-04-2012   #1
vilant
Default Part #
Could someone do me a favor that has access to the parts list? I am a paying member, but for some reason I don't see a member's only section on the home page, where the part list is supposed to be. I need the part # for the rubber coupling that connects the PCV and purge lines to the plenum under the throttle control assembly on a 1990. Mine leaks no matter how much tie wrapping and finagling I do. It is one solid block of rubber with 2 holes bored through it. Was hoping to order ASAP, instead of waiting for the glitch to be fixed. Thanks .
Old 11-04-2012   #2
efnfast
Default Re: Part #
I think I bought mine from White Racing.
Old 11-04-2012   #3
vilant
Default Re: Part #
Do you have the part #?
Old 11-04-2012   #4
vilant
Default Re: Part #
Nevermind, glitch fixed, talk about quick. Thanks Dave. Doesn't matter anyway because the part no longer exists.
Old 11-05-2012   #5
efnfast
Default Re: Part #
yea, I looked at Kurt Whites site last night and could not find it. Guess I'm glad I bought mine when I did. What did you find? - Steve
Old 11-05-2012   #6
vilant
Default Re: Part #
Nothing yet. I'm looking into rubber blocks and drilling my own holes (not sure how well it will work). There is quite an array of rubber types out there, figure a high temp, oil, and fuel resistant one should do the trick. If not, then I'll just use 2 hoses and clamp them on.
Old 11-05-2012   #7
efnfast
Default Re: Part #
You said "Glitch fixed". What was the glitch?
Old 11-05-2012   #8
vilant
Default Re: Part #
I couldn't access the parts list in the member's only section.
