#21 |
![]() Join Date: Aug 2012
Ok so i get home and look for my.good multimeter and cant find it so i grabbed my 10 dollar special analog meter set it to 50 mA DC and put it between the negative battery cable and the post and it pegged out my meter for a second and popped the fuse in it...so i just left the negative cable unhooked and came in...got to get some fuses and find my digital multimeter...
#22 | |
#23 | |
![]() Join Date: Feb 2006
connected to the terminal behind the battery. So there's a lot of stuff to disconnect one at a time whilst trying to find the offending circuit. My best guess is to look for whatever aftermarket stuff you have first. The factory circuits that fail are likely due to sticking relays - like the fuel pump. Good luck ...
#24 |
Ok so i got my good multimeter and set it to volts this time...between the ground cable and negative terminal it read 12.83 volts. I flicked it to 200ma fused and it pegged and popped my fuse. Sooooo maybe alternator diode??
#25 |
![]() Join Date: Oct 2004
What brand and model meter? There's a "rush" initially like mentioned earlier. Set your meter to AMPS not Ma and make sure the cables are in the correct ports. Set to AMPS before using! It sounds like you're mentioning you switched it "while connected". Don't know?
#26 |
![]() Join Date: Jul 2007
Post a Picture of the Multimeter or the brand and Model and we will figure out the correct connections for you
#27 |
Its a craftsman 82141. I didnt switch it while connected. The batter had been unhooked for a whole day when i tested it. I would post a pic but not sure how to do that from this phone. I put it on 200 ma ac
#28 |
Ok set the meter to the 10A setting. Leave the black lead in the middle plug. Put the red lead in the left plug. Assuming you have the + off the battery. Red goes to battery + black to + cable. Everything off see what the drain is.
#29 |
Well dumb old me...i didnt pay attention to the ac/dc settings. I switched it to 200m dc and it reads a 2.7
I blew the fuse on the 10 amp leg. I will see if i can find a replacement tomorrow. Last edited by robbz28; 10-18-2012 at 09:32 PM. |
#30 |
Ok so i unhooked my headlights and underhood lamps (they would try to run when i xonnected the meter) I set the meter like you said and got .27 volts i did it on the negative side as well and got .27 volts again.
