#1 | |
They will make you a very nice 425-435 rwhp 368ci. in the $20-23K range. You do know Pete makes more power with a stock 350ci. right ![]() |
#2 | |
I'm making 435rwhp w my stock bottom 350, GVD ported heads(small ports), and Pete's intake cams. Marc is claiming 510chp w just his ported top end and heads, stock cams. One question is whether Hib needs to pass emissions w his LT-5? |
Good to hear Marc has up'ed his game to a 430rwhp 350. As for the others I have not heard of any updated porting/cams...
#4 | |
![]() Join Date: Dec 2005
I'm making 508 chp with a M. Haibeck 500hp package. |
#5 | |
![]() Join Date: Nov 2007
For $10k a closed deck block is possible. Porting, depending on personal skill, can be a DIY project, or for (about) $5k or $15k total, a 391 would be possible. Just seems (to me) to be such lost opportunity to pick up some serious performance gains, for roughly what a 368 used to cost 15-20 years ago... Example: ![]() And, with some minor improvements since discovered, maybe 440 RWHP may be in store for this stock bottom, stock cammed, stock TB motor. Just sayin.... P. |
#6 | |
![]() Join Date: Dec 2003
BINGO!!!! & Stock Nikasil is better. ![]() Today 368 is worthless Still waiting to hear the oil issue with closed deck,any documentation on this. Pete
'91 #1635 PoloGreen 350 LT5 11.09 @ 129.27 11.04 @ 128.86 474RWHP 400RWTQ http://www.youtube.com/watch?v=SFNFOhGGlR4 http://www.youtube.com/watch?v=ZlRIOMwaDYY https://sites.google.com/site/peteszr1garage Last edited by Pete; 10-08-2012 at 01:02 PM. |
When comparing cost of a complete overhaul, with new OEM pistons, liners and rings, going the 368 route with good quality aftermarket piston/rings, rods and ductal iron liners is not significanty more expensive and has its advantages. Besides a little more displacement you can up the compression ratio to 12:1 for more power & torque and hone the liners installed the block using a modern deck plate honing methods for better piston and ring fit which helps with oil control. Aftermarket pistons also allow you to go with longer rods with the advantages a higher rod length ratio brings.
#8 | |
Question still remains is the stock motor blown/broke? If not,it's a waste to spend money for a 368, not worth the dollar to HP Do a good top end,raise compression use Jerry's head gaskets a whole lot cheaper then doing a complete 368. I don't think $12k-$15k is worth the extra 20hp Basicly the pros & cons of spending this kind of money for an extra 20hp. "It's all dollars and no sense" ![]() Pete
