Old 10-01-2012   #21
vilant
Default Re: Trying to restore the TB coolant flow
Yah, I've heard of that happening. I solved that by using rubber gaskets on both the plenum and TB cover. That was over 10yrs ago. No runs, no drips, no errors since. The side benefits are you don't have to pay for new gaskets because they don't stick, rip apart nor allow coolant to migrate toward the paint.
Scott, where did you get the rubber gaskets from? Did you buy them complete or did you buy a sheet of rubber and make your own?
Joe
1990 Bright Red ZR-1 #2599
Old 10-01-2012   #22
scottfab
scottfab's Avatar
Well, I did cut them myself but I made a template (the OP may recognize the material I used for the template)
The template is not really necessary. You can just put the plenum down on the rubber sheet (1/8 - 1/4 thick) and trace around it with a ballpoint pen, then cut it out. I took the extra time to cut the template because I thought I'd be cutting more of them. (nope, not so far)
Rubber is the ideal material. It makes a great seal, does not stick and very heat tolerant a the temps on the plenum.
Scott
Old 10-01-2012   #23
vilant
Good thinking. Thanks.
Joe
