Go Back   ZR-1 Net Registry Forums > Club Regional Areas > Mid-Atlantic Region
Old 09-19-2012   #1
dredgeguy
dredgeguy's Avatar
Default No reverse lights
Noticed I have no reverse lights. Changed the two bulbs but no change.
Any suggestions?
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 09-19-2012   #2
Default Re: No reverse lights
there's a switch on the tranny that I can't remember the name of that needs to be replaced
Old 09-19-2012   #3
scottfab
scottfab's Avatar
Any suggestions?
Common issue with the backup switch mounted on the ZF6 tranny on the drivers side.
Make sure it has not loosened up.
Scott
Old 09-19-2012   #4
dredgeguy
dredgeguy's Avatar
Thanks for the feedback. Glad I live in WAZOO land.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Old 09-22-2012   #5
Aurora40
Aurora40's Avatar
FYI, you barely need to jack the car to get to it, though it would be simple at a WMD. Bill B. used to loan out a special wrench that made it much easier to replace, just ship it back to him (or the next guy) when you are done with it. Don't know if he still does that?
That and the high-mounted brake light are a very common switch failure, so 99% chance it is a simple fix.
Old 09-22-2012   #6
scottfab
scottfab's Avatar
I posted these on the wrong tread the other day.
Pics for ref.
Scott
Old 11-01-2018   #7
jpalmer1717
Are you able to show what tool (and length) is used to reach the reverse light switch without a lift? Thanks!
jpalmer1717 is offline   Reply With Quote
Old 11-01-2018   #8
efnfast
I bought a 7/8" combination wrench. Cut off and used the open end at about 5.5"
Old 11-01-2018   #9
George Maz
Homemade tool I've seen, and closeup of trans switch 1990.IMG_0828comp.jpeg20180616_200838.jpg20180616_200911.jpeg
Sent from my SM-N920V using ZR-1 Net Registry mobile app
George Maz is offline   Reply With Quote
Old 11-02-2018   #10
Mystic ZR-1
Mystic ZR-1's Avatar
I've got a bunch of wrenches, sockets, screwdrivers and other bits I've modded over the years for a one time job....
