Old 08-14-2012   #1
brentoleary
Default air bleed with plenum coolant bypass
I am planning to put on some SAMCO hoses and bypass my plenum coolant as outlined in the April 2007 Heart of the Beast article. I saw a few pictures where it appears others have bypassed the plenum coolant without air bleed hoses as shown in the write up. I like the cleaner look of no top end plumbing, but I am far more concerned about functionality than looks.
Any thoughts on the bleed hoses?
Any advice in general for the job. This is my first attempt at doing anything to the Z, so I am excited and nervous at the same time. I have a 1995 factory service manual from a previous vette, is it worth ordering the 1991 specific manual and the LT5 supplement before I start or is the 1995 manual close enough for this job?
brentoleary is offline   Reply With Quote
Old 08-14-2012   #2
VetteMed
Default Re: air bleed with plenum coolant bypass
I'd suggest having the 91 manual. There were changes throughout the years.
Old 08-14-2012   #3
Hammer
Hammer's Avatar
Talking Re: air bleed with plenum coolant bypass
Hi Brent,
Give us some more details on your car, colors and number. How many miles and we may be able to help more.
Also check out the following websites for some good tech articles and
reference material before you start.
http://pnwzr1.net Enter the site and on the left find the tech section
www.zr1specialist.com
Do get a service manual for the year you are working on though.
Oh yeah, we like pictures too.
Welcome
Old 08-15-2012   #4
Scrrem
Scrrem's Avatar
I plugged my injector housings and removed all the coolant tubing from the plenum but was concerned about air pockets forming (Mark H had some issues with this). I drilled and tapped fittings on the back side of the injector housing and ran the hosing under the plenum and back to the recovery tank. Here's some pics of the finished product.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Scrrem is online now   Reply With Quote
Old 08-15-2012   #5
Rich, that is pretty interesting for the coolant.. I assume it is working out fine.. no air pocket issues
Old 08-15-2012   #6
brentoleary
Originally Posted by Hammer View Post
Hi Brent,
Welcome
My car is black with gray interior and #1164, with ~118K on the clock. Has some port work (Corey Henderson), OBX headers, Borla exhaust and 4:10 gears. It had a small coolant leak from the Tee on the plenum on the passenger side. I removed and epoxied the Tee, but it still leaks, so I figured I'd try the coolant reroute and get rid of the possibility of a leak.
Thanks to everyone for the input, I'll check out all the links and try to post some pics tonight. I am still waiting for my gasket set from Jerry's so I have some more time to read up before I get started, hopefully this weekend!
Old 08-15-2012   #7
Scrrem
Scrrem's Avatar
It worked out great, all the air blead out fine, no air pockets. I was concerned because the installed fittings are not at the highest point in the injector housing, but no air pockets. I kept a close watch after start up checking for any hot spots.
Rich
Ron Davis Radiator
Old 08-15-2012   #8
Scrrem
Scrrem's Avatar
Default Re: TB Coolant Elimination Completely with NO Air Bleed
I assume you mean watching your temperature gauge. The best is to watch HVAC display engine temps in deg C. Using HVAC Display for Engine Coolant Temperature
Opps. Yeah, I mixed that up. You need to check the temp gauge and do a feel test on the coolant tubes and crossover pipe to ensure water is flowing thru them. Marc told me he discovered the air pocket when he saw his temp guage going up but the lower portion of the coolant tubes and the crossover pipe were stone cold, so he shut down the engine.
Rich
Ron Davis Radiator
Old 08-15-2012   #9
Paul in VA
As gorgeous as that engine looks in the pictures above, it looks even better in person! It is simply AWESOME!
Paul in VA is offline   Reply With Quote
Old 08-15-2012   #10
Scrrem
Scrrem's Avatar
Thanks Paul.....it may be all coming off if I can't pass emissions in Nov....We'll see.
Rich
Ron Davis Radiator
