#11 | |
![]() Join Date: Nov 2007
![]() P. |
#12 | |
I used the blue LT - on the header bolts that I got from ACE H/W. I used them inconjunction with a new gasket from Jerry. For insurance, I smeared a film of red high-temp RTV on both sides of the gasket - overkill on a new one, perhaps? AnywayZ, no leaky after a couple years and counting. ![]() P. |
#13 |
![]() Join Date: Dec 2003
Loctite 242, 243 & 262 is only rated to 300F. Heat is used as an aid to dissassembly. Vibration is the cause of fastener loosening and only occurs under running conditions. I haven't checked the actual, operating temperature of the cyl head at the exhaust port, but I would expect temperatures in excess of 300F.
Considering the difficulty of accessing header bolts and the small tools used, I would not recommend the use of Loctite on header/manifold bolts. It could make disassembly problematic.
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 03-15-2012 at 10:40 AM. |
#14 |
![]() Join Date: Dec 2004
Thank you Gentlemen, Cliff, Paul and Jerry.
![]() Paul, I use some form of permatex on all my gaskets via buttering so I'm hearing Ya with that one! Cliff, what can I say? You are complete right down to the crossed "T-ees" and "dotted I's"! I'll go run down the links and do some reading. Thanks amigo. Jerry, I never considered the temp limits of any of the loc-tite products. My bad. ![]() ![]() Tom
#15 |
![]() Join Date: Apr 2012
Two questions. First, following up a separate discussion with Jerry, have any of you seen an aluminum oil drain plug (Jerry says he has not) and second, what size is the oil drain plug?
Thanks! John |
#16 | |
Andrew |
#17 | |
John |
#18 | |
I think the stock plug uses a 13 or 14mm socket. Nothing exotic. |
#19 |
![]() Join Date: Oct 2004
the 5/8-18 is correct for the thread & pitch, 9/16 for the box-wrench and I don't believe a ZF fill or drain plug is aluminum. Mine are "magnetic"! Those are in an NOS "Blue tag" but I believe I've checked those in the car also!
#20 |
