Old 07-06-2012   #591
Default Re: LT5 Assembly Project
ran the egnine with no header, no ticking.....might be masked by exhaust
Vid below; for some reason no flamage on the photobucket version....you can see it on my camera
Old 07-06-2012   #592
mike100
^^^ haha..that's crazy. anyways, if you can see the hole, it will definitely tick. it doesn't take much.
Old 07-07-2012   #593
Good deal Lee! I'll bet that's the tick.
Old 07-08-2012   #594
Still have a tick, not sure what the issue is at this point.
Old 07-08-2012   #595
Got a stethoscope ?
Old 07-08-2012   #596
yes....checked the DS cam cover has more lifter noise than the PS cam cover but nothing on par with the tick I hear. Will check more today....
LAstI check with the Tech 1 no knock retard, so unlikely a rod or crank bearing
PS: Dom was wondering if you might be able to burn a chip for the 92? Have the new chip
Old 07-08-2012   #597
Lee,
We can use the last calibration I have before doing the heads and cam on this motor. Our motors were pretty close at that point in terms of mods. Having fixed your knock retard issue, maybe now you can take advantage of the changes. Give me a shout when you want to get that.
Old 07-08-2012   #598
Took the car out, ran the hell out of it.....5-6 7500rpm runs. no knock counts at all. Then took it up to 7500 and held it 5-6 seconds.....then I came up to a stop sign..no tick. Cruised on the highway back to town, pulled in a parking lot, faint tick. Then parked it, came out and tick was noticeable.....then drive it an tick went away again.
Pretty sure this is an exhaust issue....maybe there is a reason I got the headers for $500.00
Lets hope thats it for the drama, car feels strong; we'll soon see if the seat of pants dyno is accurate....
Old 07-09-2012   #599
Originally Posted by mike100 View Post
use a small diameter vacuum tube rather than the stethoscope to find exh. gas leaks. stick one end in your ear and run the other open end along the header flange and all pipe weld joints.
as an example of how easily you can hear the smallest airflow, blow across the tube to test it out. You will find a small leak this way.
OPen tube...Great tip! Especially for finding an exhaust leak.
P.
Old 07-10-2012   #600
drove the car 320 miles the last 2 days, runs great....biggest issue is that these tires will never hook; gun it from a roll and the car kicks alittle sideways and burns them up....hope the dyno numbers match the seat of pants o meter.
BLMs at cruise are 116 and 128 at WOT
