#21 |
![]() Join Date: Jun 2007
vettemed has one for sale in Z-R1 parts for sale.
#22 | |
![]() Join Date: Dec 2004
![]() You pulled the DTC's you listed in your first post, right? You used the paper clip method? I think I should review them and my diagnostic thought process so I may be more helpful to you. I'll do just that and report back later today! ![]() Tom
#23 |
Well very interesting find. Non of the sensors was causing my problem or a vacuum leak. I was able to borrow a ecm from a friend and put my prom in it. Now no SES light and all seems to be working right. The secondaries are coming on and it is running good. My ecm was rebuilt less than 6 months ago. May have gotten a bad rebuild. May be sending my ecm off to K&B Special Corvette Parts. I plan on taking the car down to Corey's in June and let him tune it and maybe check the injectors and weld up my corsa exhaust. I am getting short surges at cruising speeds.
Don |
