View Poll Results: Which oil filter do you use? | |||
AC Delco | 68 | 27.42% | |
Amsoil | 1 | 0.40% | |
Baldwin | 0 | 0% | |
Bosch | 66 | 26.61% | |
Fram | 13 | 5.24% | |
K&N | 12 | 4.84% | |
Mobil 1 | 54 | 21.77% | |
Napa | 12 | 4.84% | |
Penske | 0 | 0% | |
Pennzoil | 1 | 0.40% | |
PowerFlo | 1 | 0.40% | |
ProLine | 0 | 0% | |
Purolator | 3 | 1.21% | |
Quaker State | 0 | 0% | |
STP | 0 | 0% | |
Wix | 17 | 6.85% | |
Voters: 248. You may not vote on this poll |
Thread Tools | Display Modes |
10-17-2009 | #31 |
Re: Which oil filter do you use?
On a related subject.... I see Mobil 1 is $21 a jug at Wallmart... not bad for 5 quarts.
91 ZR-1 #661 Watsons, 3" exhaust, Borlas... Hurst, 4.11s, Samco, RD radiator, gel coated motor... turquise / black |
10-30-2009 | #32 |
Ya but......WalMart does not have Mobile 1 filters
10-31-2009 | #33 |
YA BUT... You don't need a Mobil 1 filter... I use the Bosch... Autozone carries them.
BTW... Walmart is over $2 a quart cheaper for Mobil 1 oil than Autozone
09-06-2011 | #34 |
I read on Marc's site the Bosch drains thru the check valve after 24 hrs, so I'm gonna try the Wix from NAPA
[FONT=Arial Black]#1679 in '91[/FONT] |
09-06-2011 | #35 |
Thats new updated Marc info
09-19-2011 | #36 |
The previous owner used Bosch and that's what I'm going to continue to use. No rattle from what I can tell, pressure comes up quickly, oil stays clean.
I've only owned the car for about two months so my opinion doesn't really matter.
[B][U]1991 No. 519[/U][/B] |
09-19-2011 | #37 |
I will be switching from the Bosch to the WIX (NAPA) per Marc's new recommendation.....
Bob Anderson 1990 #2405 White/Gray Haibeck chip,4:09 gears,Power Effects Exhaust,5 spoke chrome,C5 brakes,49th Street rockers,K&N,Hurst,Headers,Upper & lower ported Minnesota State Director Founding Member #19 |
09-19-2011 | #38 |
I've been using the Bosch for several years, but I've noticed more chain rattle with the last 2-3 ... Marc's new info just confirms this. Makes me wonder if Bosch has "changed" their filters. Shame, I liked the look of the Bosch with the label removed. I will be trying alternatives soon ... may even change to another filter in the next few days even tho I changed oil/filter a couple of weeks ago. This last Bosch filter has more chain rattle than any filter I've used.
George |
04-22-2012 | #39 |
Mine is not even shown. Valvoline oil filt.
But I also have some Frams.
04-22-2012 | #40 |
I use Mobil 1 Extended performance and the Mobil 1 Filter that goes with it. No chain rattle or weird oil pressure readings on my 54000 mile LT5. I get it all at advance auto parts which normally does a deal on the mobil1 which gives you 5 quarts and a filter. I buy two kits each time and have some extra filters. Each time I also have an extra quart, so pretty soon I'll have enough quarts and filters to do it for nothing, sort of.
1994 #293 ZR-1 Stainless Works Long Tube Headers, B&B catback w/ X-Pipe, 18" Shelby Series One Wheels, SLP CAI. |
