![]() Join Date: Feb 2006
thanks for the info guys...is there any specific tools i'll need for this clutch/flywheel changeout....i got the clutch alignment tool, but the manual shows a tool for removing the pilot...is it Z specific...just wanna have all part and tools ready for the job...no one replied if they would balance the flywheel???? talk to me guys, i'm heading into unchartered waters...but i will succede!!!! with the proper info.... brody p.
#2 | |
![]() Join Date: Feb 2009
Rich
thanks guys, ill save the cash for balancing, no special tools needed, where do i get the bolts [arp] you mention, do they have a bolt kit LT5 Fidanza specific, if not will they know what quantity and size/length i need. just covering my bases...thanks brody p. ps. the seal you refer to is that the tail shaft seal on tranny??
#4 | |
Check out the SRP website. Bolts are on this page. $112 but piece of mind for me. http://www.zr1products.com/#!products Also the seal we are talking about is the rear main on the motor. It will be exposed once clutch and FW are removed. Good time to R&R it. I knew there was a reason for not pressuring the pilot bearing. Thanks for the reminder Sccrem |
thanks for the info xfire!!! brody p.
i spoke with jim jandik yesterday and he recommended going back with the stock clutch setup, i really didn't know if i would like the noise created by the fidanza. jims a great guy, he spent the time to explain in detail what i'm looking forward to w my clutch install, i'll keep the fidanza/blue spring disc i got from Lee as spares for the time being. i can't wait for the parts to arrive from JIM!!! going to try to get the tranny out this weekend [if wife allows] and get the underneath cleaned up in anticipation for mey new clutch to arrive and get her together and on the road again!!! brody p.
![]() Join Date: Mar 2007
Brody you can send it back if you want and I will give you a full refund and cover shipping...
#8 | |
http://www.summitracing.com/parts/ARP-654-2750/ http://www.summitracing.com/parts/ARP-200-8688/
#9 | |
![]() Join Date: Nov 2007
FW bolts... I believe it was Hammer that suggested I buy the 7/16 x 20s (?) x 1-1/8" grade 8s (I got mine at ACE H/W) and 8 SBC hardened head bolt washers I got from an auto parts store. Use RED Locktite and torque to spec. Matter of fact, I followed Hammer's advice pretty much to the letter; the FW bolts, and tapping the holes for the PP bolts to accept the longer (I bought the SRP kit - bolts and tap). Works like a friggin charm! P. |
#10 |
These are the strongest bolts I've found that are of the right length for the Fidanza Al flywheel. Go with 3 packages as 8 bolts are required.
http://www.summitracing.com/parts/ARP-230-7303/
