Old 04-03-2012   #1
ZR-1Mike
ZR-1Mike's Avatar
Default Not Running!
I'm needing a little help. I've not been driving my '91 much in the last year and a half and last October on a trip we stopped for lunch and when we came out the engine started fine but idled and maintained cruise power poorly. I replaced the coils over the winter and now under WOT it runs like a beast but still has major problems with smoothness at idle and cruise. There is a tech in town trained 20 years ago and he found a bad vacuum line but won't take it any further. I live in SE Oklahoma and am looking for someone competent on LT5's. Anyone out there have any ideas about a fix or someone that might be able to help it? Now that she's not running I really miss her!!
ZR-1Mike is offline   Reply With Quote
Old 04-03-2012   #2
Default Re: Not Running!
I wonder how far jerry is from you. he's in edmond i think
Old 04-03-2012   #3
1990 quasar blue
Any chance you popped the hose off the map sensor?
Old 04-03-2012   #4
ZR-1Mike
ZR-1Mike's Avatar
The first thing I checked was the map sensor, but wasn't that lucky for it to be that simple! I've met Jerry a couple of times, do you think he knows someone near by to look at it? I'll leave him a message... Thanks
Old 04-03-2012   #5
1990 quasar blue
Stock injectors still? Any check engine light?
Old 04-03-2012   #6
VetteMed
If you were able to change coils yourself, then you already can do everything necessary to rule out vacuum leaks under the plenum. A mityvac or similar tool can be used to pull a vacuum on the various lines and fittings under the plenum, unless of course there's something obviously disconnected when you get in there.
If the cruise and/or HVAC aren't working 100% properly, then that would increase the likelihood of a vacuum leak being present.
I recently found a vacuum leak where the brake booster hose meets the plenum. It seemed snug, but after I put a hose clamp on it to snug it up, the idle smoothed out considerably.
Also, a failing throttle position sensor could do funny things at part throttle (not usually at idle, though).
