Old 03-30-2012   #11
Default Re: Hp question
Originally Posted by efnfast View Post
Correction number was .96 as I remember. To convert to SAE.
He mentioned NH correction numbers are usually low.
Did he pull the .96 out of his butt or was that the correction factor for that time and day. Dyno should calc the CF each time. Also, on the Dynojets, there is a smoothing factor. It cuts off peaks and valleys. A setting of 1 gives you the actual peak number. Could be a diff of +/- 5 depending.
Old 04-01-2012   #12
efnfast
No, he showed me on the screen what the correction number should be. Still , I think I'm happy with this number. Jones'en to get the exhaust done.
Old 04-01-2012   #13
SteelBlueZR1
Also, the Corvette action center has a GM engineering document that states the drivetrain loss for ZF6 wheel HP calculations as 16%. My ZR1 1991 with chip only dynoed at 321 rwhp yesterday. 321/.84 = 382 crankshaft HP. A 91 zr1 with chip + exhaust dynoed at 340 yesterday, so all the numbers and power gains make sense.
SteelBlueZR1 is offline   Reply With Quote
Old 04-02-2012   #14
Bob Eyres
Most stock 91's I've seen dyno in the 320-340 range. Mine with headers and 3" exhaust only did 336 at the wheels, (not great).
Keep it cool, open up the airflow, it'll scream.
BTW, love that "Steel Blue"
Old 04-02-2012   #15
efnfast
Headers and exhaust go on as soon as it comes back from Swaintech. It's got a K&N in the stock air box, I think I'll change to an S&L with the claw design and three filters, not sure if that is money well spent or not. Then a Marc chip once I know what mods I've made. I'm not going to dyno again untill I get all of this stuff done. Wish I could do it between every mod, but I'd rather invest that dough into hp.
