#11 |
![]() Join Date: Dec 2003
I have been testing some new material, imersed 1/2 in Mobil 1 syn oil, @ 300F for 2 hrs with no deterioration. I like the mesh & plan to cut it into the right size & put it up on my store. No pictures yet. Will post soon.
http://jerrysgaskets.com/store2/root...roducts_id=673 ![]()
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 06-09-2014 at 11:23 AM. |
#12 | |
Must be a solid rumor the ZFDOC told me the same thing Paul hence my procurement of the new foamy squares. I dont know either I figure while were here foam it lol
#13 |
#14 | |
What were you full list of mods again? Are you running 4:10s Fidanza?
#15 |
I think you need to be judicious with it. If its packed to dense it will clog which is what appeared to happen w mine. Oil tends to collect on it and that impedes the vapor. The telltale for me was the small pool of oil in the bolt boss right next to the vent tube. I would clean it and it would seep back. I would also get a burning oil smell when I would accelerate hard. Had multiple sources of small oil leaks.
Motor probably has 2k miles on it. |
