#31 |
![]() Join Date: Nov 2011
#32 |
![]() Join Date: Mar 2004
As stated above the contact patch is 11.25 inches.
#33 |
Thanks Bill, I saw that, but didn't know if there was some discrepency for some reason. Starting to question the set I've got coming for the Spring.
Steve ![]() |
#34 |
OK Steve. A buddy of mine has 315 Sumo's on stock 17 x 11 wheels and says they cause the tread area to be rounded causing less contact. Keep us posted what you find.
#35 |
Pretty sure ZZZZZR1 runs the 335 PS2's. David, can you pull a tape for us?
#36 |
Sorry Bill, just backed up. Looks like in #27 reply here you already pulled a tape.
#37 |
Not a problem Steve. Confirmation is always a good thing. Hoping to more measurements on other 315s and 335s.
#38 | |
![]() Join Date: Jan 2012
#39 |
![]() Join Date: May 2010
Okay, I just measured and Nitto NT555s on stock wheels in 315 are 11.50 inches contact patch on the ground.
#40 | |
The only tire that has an awkward fit are the suimi's and boy are they skinny!!!! ![]() David |
