Old 01-22-2012   #1
RHanselman
RHanselman's Avatar
Default Re: Best Rear Wheel Hub Assembly?
Originally Posted by Coupe89 View Post
I had the same problem turned out to be bad u-joints.
I don't seem to have any play in the Hub however I do have a little lash in the right side U-Joint... Also, the tires are as hard as rocks... I'll switch some rubber around and see what happens...
Old 01-22-2012   #2
gbrtng
gbrtng's Avatar
If there is no play in the hub - top to bottom or front to rear - then the bearing is not the problem. Sounds like a tire with some cupping ...
