#11 |
It's 9:49 am you guys should be wrapping it up by now =D>, Dave J make a beer run already?
#12 |
Ricky
7 z brothers showed up and we have an hour or so left Great day! Met another wazoo brother from the Richmond area!! Thanks to Rich for hosting and Phil for his expertise!!!! ![]() David |
#13 |
![]() Join Date: Feb 2009
Transmission out....installing the heat matting.
Some of the WAZOO.. Phil's main seal installing tool.... Phil installing the bellhousing... David keeping up with the forum... Darrin II....
1990 Bright Red Coupe #608 380 Stroker, Ported Heads/Intake/Housings/TB Haibeck Secondary Delete Chip / Pete's Cams George Braml Intake / FIC Injectors Coated SW Headers / Corsa Bill Boudreau B/B ZF6 / Viper 4.10 gears Ron Davis Radiator Pioneer AVIC-Z140BH NAV Fikse FM5's 285 / 335 / C6 Brakes WAZOO Member Last edited by Scrrem; 01-15-2012 at 06:40 PM. |
#14 |
I had a great time meeting all you guys today, thanks again for having me out. I learned a lot.
#15 | |
Rich
#16 |
![]() Join Date: Jan 2009
Jeez, I miss 1 tranny pull and you fellers have to use a jack.....WTH????
90 ZR-1 #0951 Bright Red (sold) 06 Z51 MN6 Velocity Yellow (sold) 2023 C-8 Z51 ELB WAZOO Member |
#17 |
![]() Join Date: Mar 2004
#18 | |
![]() Rich
1990 Bright Red Coupe #608 380 Stroker, Ported Heads/Intake/Housings/TB Haibeck Secondary Delete Chip / Pete's Cams George Braml Intake / FIC Injectors Coated SW Headers / Corsa Bill Boudreau B/B ZF6 / Viper 4.10 gears Ron Davis Radiator Pioneer AVIC-Z140BH NAV Fikse FM5's 285 / 335 / C6 Brakes WAZOO Member Last edited by Scrrem; 01-16-2012 at 03:14 PM. |
#19 |
![]() Join Date: Aug 2006
Thanks for hosting this Rich. Always great to get together w/ the WAZOO gang!
Darrin - you may become obsolete! |
#20 | |
![]() Hopefully, though, the jack still gave David a hard time about bringing an iPad in the first place to a trans pull. Otherwise, I don't see how it could be considered a replacement? |
