Old 12-02-2011   #1
oricale
Default 108 amp alternator in a Z??
I pulled the alternator and is shows it being a 108 amp alternator,.!
??what kind of issues can arise from a low amp count on our cars??
oricale is offline   Reply With Quote
Old 12-02-2011   #2
Default Re: 108 amp alternator in a Z??
Too many electrical issues to list. In short underpowered
Old 12-02-2011   #3
Don't do it
Old 12-02-2011   #4
oricale
Cmon',..you know I wont reinstall it but it could be why the car is having issues !!
Old 12-02-2011   #5
that it could these cars are battery hogs. swap it and see what happens
Old 12-02-2011   #6
gbrtng
gbrtng's Avatar
It might not be able to keep up with the current load with EVERYTHING turned on. High beams, AC blasting, aftermarket sound system hogging the rest ... I think the stock alternator is 140 amps, but 108 should be enough for daily use. The trick is to make sure the battery terminal voltage is above 12.6 volts under full load.
Old 12-02-2011   #7
Concur. and C4s are Battery whores. Full 12.69 volts all the time or stranges things happen.
Old 12-04-2011   #8
JThomas
JThomas's Avatar
I believe the stock alternator is 124 amps. I recently had to replace one on my '92.
Joe Thomas
Corvette Club of Michigan
NCRS-Michigan Chapter Member
NCM Master Ambassador
Former NCM Board Member
1991 ZR-1 Melon Copper Metallic/Black
1992 ZR-1 Bright Red/Black (Sold)
1995 ZR-1 Bright Aqua/Gray (Sold)
2012 ZR1 Super Sonic Blue / Dark Titanium
JThomas is offline   Reply With Quote
Old 12-04-2011   #9
As an example, fluctuations in battery voltage are compensated for by ECM modifying injector PW. However, you'd like to be at the power level where the vehicle and systems operate at optimally.
Old 12-04-2011   #10
Blue Flame Restorations
The build sheet for my 88 called for a 120 amp unit. I would think the later cars would be at least 124.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
