Old 06-01-2010   #21
ScottZ95ZR1
ScottZ95ZR1's Avatar
Default Re: Door Change(s) Between '90 and '91 ?
Thanks Jeff - Mark has an awesome car.
ScottZ95ZR1 is offline   Reply With Quote
Old 10-24-2010   #22
One minor change in door trim happened somewhere in early 91 production.The trim on the early 91s has 7 threaded 10MM studs that bolt it to the door while a production change had the trim with a 1 stud at each end and clip retainers in the middle of the door.To get the the early trim off the door the door has to come completely apart.I dont know why G.M. would design the early 91 trim to be bolted on when the trim for the 90s was of the later design with the snap clips.I believe this bolt on trim was the only design on a C4,lucky me.
Old 09-28-2011   #23
Originally Posted by phrogs View Post
90's and 91's both only had a thin plastic cover under the door panel, didn't really do much of anything I have never noticed anything "special" in the 91 doors over the 90 doors.
Thats correct when I R&Red both my 90 and 91 doors the plastic sheet was there. I upgraded to that foam insert that MADVET sells? Improvement who knows
