Old 06-12-2011   #331
Hog
Default Re: LT5 Assembly Project
Cool vid, thanks for sharing.
Seeing the process makes me wonder how durable the big bore LT5 engines are compared to a stock bore engine? There must be a lot of work into making the 415/427/441 inch engines. And mega amounts of money.
peace
Hog
Old 06-13-2011   #332
Yea, thanks Lee! I'm finding this thread very educational for me! This is great stuff.
Old 06-13-2011   #333
HAWAIIZR-1's Avatar
Lee,
You are heading for a record with the longest lasting thread, if not already the winner. Many of us have been following this for the past 2 1/2 years. I can say that it definitely helped me while I was building my motor in my garage like you. Thanks for sharing all your trials and tribulations!
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 06-18-2011   #334
Bad day today...
The bearings I am using were recoated by Calico....original to the car. Went through torque/angle on all of the cradle bolts, and the crank is locked.
Did some testing.....2,3,4, bearings are locking the crank.....replaced the recoated thrust bearing with a new OEM and crank would spin as long as 2,4 were not torqued down.
Seems odd....any thoughts?
Old 06-18-2011   #335
Pete
Pete's Avatar
Are you trying this with anearobic sealent on the cradle.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 06-18-2011   #336
Polo-1
somethings wrong..
The CT-1 coating is .25-.30 mils this is less then .0005 not .001
Old 06-18-2011   #337
Sealant is on the cradle surface.....
Old 06-18-2011   #338
Blue Flame Restorations
Was the block/caps line bored?
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 06-18-2011   #339
No allign bore as no known history of a spun bearing, etc
Old 06-18-2011   #340
No line bore as no known history of a spun bearing, etc
If everything mic'd ok and all bearing sizes checked out and crank checked out, it doesn't make sense??????
Has the crank ever fell over while standing on end? I've seen them bent from this. Doesn't take much to do this.
If the crank is not bent, would it make sense to use shims on specific caps? (given that the crank is straight) We do this on every six cylinder used on my 53 restos.
