#21 |
Hey guys,
I have received the McCleod 1502 bolts. They look and fit like the real deal. The shoulder is 0.375" diameter and 1.160" long. The total bolt length from the bottom of the head to the end of the threads is 1.600" The shoulder extends 0.086" past my LT1 pressure plate So they seem to work perfect for an application using the LT1 thickness pressure plate, which I think, A26B, would be your combo 1 for you ZR1 guys. Thanks everyone for your help. I will post up some pics of the McLeod bolts shortly. |
#22 |
#23 |
![]() Join Date: Dec 2003
Looks like they should work properly. Thanks for sharing the information with excellent photos. Your work will wrap up this subject with the proper solution to the thinner, replacement pressure plate.
#24 |
![]() Join Date: Aug 2008
This thread was such a nail bitter. I can finally relax now.
#25 |
![]() Join Date: Aug 2006
Just saying 'thankyou' (even if over 3 years later!) to this thread - still very useful stuff.
Steve |
#26 |
