Old 02-15-2011   #1
rhipsher
rhipsher's Avatar
Default Codes.
Im very happy with the work the body shop did but I noticed the car was running kinda rough when pulling out of the body shop. And almost didnt run at all when starting it up to leave work. So natually I pulled the codes when I got home. H32 34 36 38 74. I suspect all the codes in the 30's are banks. Just don't have an SFM to confirm it.
Old 02-15-2011   #2
1990 quasar blue
Default Re: Codes.
Any chance they blew off the map sensor hose?
Old 02-15-2011   #3
rhipsher
rhipsher's Avatar
Default Re: Codes.
Nope that's the first thing I checked.
Old 02-15-2011   #4
xlr8nflorida
xlr8nflorida's Avatar
Default Re: Codes.
Code 36 indicates a direct ignition system circuit fault.
Old 02-15-2011   #5
Default Re: Codes.
ZR1 ECM CODES 1990 TO 1992:
Code #12: Normal No Codes.
Code #13: Left Oxygen Sensor Circuit.
Code #14: Coolant Temperature Sensor Circuit High.
Code #15: Coolant Temperature Sensor Circuit Low.
Code #16: Direct Ignition System (DIS) Fault Line Circuit
Code #21: Throttle Position Sensor Circuit High.
Code #22: Throttle Position Sensor Circuit Low.
Code #23: Manifold Air Temperature Sensor Circuit Low.
Code #24: Vehicle Speed Sensor Circuit.
Code #25: Manifold Air Temperature Sensor Circuit High.
Code #31: Camshaft Sensor Circuit.
Code #33: Manifold Absolute Pressure Sensor Circuit High - Low Vacuum.
Code #34: Manifold Absolute Pressure Sensor Circuit Low - High Vacuum.
Code #36: Direct Ignition System (DIS) Circuit (missing or extra EST signal)
Code #41: Cylinder Select Error (Faulty or Incorrect Mem-Cal)
Code #42: Electronic Spark Timing (EST) Circuit.
Code# 43: Electronic Spark Control (ESC) Circuit.
Code #44: Left Oxygen Sensor Circuit Lean.
Code #45: Left Oxygen Sensor Circuit Rich.
Code #46: Vehicle Anti-Theft System (VATS)(PASS-Key) Circuit.
Code #51: Mem-Cal Error.
Code #52: Engine Oil Temperature Sensor Circuit Low.
Code #53: System Voltage.
Code #54: Fuel Pump Circuit (Low Voltage)
Code #55: System Voltage
Code #56: Vacuum Sensor Circuit.
Code #61: Secondary Port Throttle Valve System.
Code #62: Engine Oil Temperature Sensor Circuit High.
Code #63: Right Oxygen Sensor Circuit Open.
Code #64: Right Oxygen Sensor Circuit Lean.
Code #65: Right Oxygen Sensor Circuit Rich
ECM
31 LCD Data Circuit-Circuit shorted to battery voltage or CCM driver open
33 Data Clock Circuit-Circuit shorted to battery voltage or CCM driver open
35 Data Strobe Circuit-Circuit shorted to battery voltage or CCM driver open
37 M Clock Circuit-Circuit shorted to battery voltage or CCM driver open
72 LCD Dimming Open Circuit-Circuit open or shorted to ground (radio & Climate control)
H History code. May be intermittant.
Code 31, 33, 35 related to the circuit from the CCM to the Instrument panel LCD.
CCM 74 is also a lighting circuit problem.
CCM 41 is loss of communication with the ECM.
Old 02-16-2011   #6
rhipsher
rhipsher's Avatar
Default Re: Codes.
As soon as this happened the first thing that came to mind was that I have been having a coolant leak thats been draining out the valley drain tube on to the floor. When I put the top end back together a year ago I noticed the drivers side injector housing to head gasket had a cut on it all the way through one side. But I figured if I put some 518 on it and torqued it down it would be ok. But if its leaking a little coolant into that cylinder than that could cause this to. I'll pull the spark plugs on that side and take a llok at them. I've got no choice. I have to pull the top end off to see where this leak is coming from and just fix it. And this may have nothing to do with the way its running. It may just be coincedence that after I got it back from the body shop my radio is dead and all these codes popped up and the car runs the same way as they do when the map sensor is unpluged but not near as bad as when the map sensors unpluged.
Old 02-16-2011   #7
USAFPILOT
USAFPILOT's Avatar
Default Re: Codes.
could it have dropped a coil pack? Maybe a plug wire is loose? Dont forget to check the easy things first.
Old 02-16-2011   #8
ittlfly
Default Re: Codes.
Radio dead too? Sounds like a bad fuse or ground. If you ahve a FSM you might check to see what else is on that circuit....or a common fuse/ground.
ittlfly is offline   Reply With Quote
Old 02-16-2011   #9
rhipsher
rhipsher's Avatar
Default Re: Codes.
About 6 months ago my dash display with the tac/speedo light would get bright then really dim and sometimes the radio would pop and crack but not often. I always check the easy stuff first. But for this to just happen all of a sudden. But a coil pack can go out all of a sudden. And so can an injector so we will see.
Old 02-16-2011   #10
Demps
Demps's Avatar
Default Re: Codes.
Free to check---> I would check that all grounds are tight.
Ted
Demps is online now   Reply With Quote
