02-07-2011 | #1 |
Cam Positioning Sensor
I have a oil leak that appears to be coming from the area around the the sensor. Are there any tricks or tips in in replacing the gasket / O ring? And where can that gasket be bought?
thanks in advance.
1994 ZR-1 # 0102...SOLD |
02-07-2011 | #2 |
Re: Cam Positioning Sensor
It looks like a standard Viton 'O' ring, pull out the old sensor and take it down to the local Napa or Kragen.
Make sure to get Viton, I don't think BunaN would handle the oil and the heat. Here's a pic of the sensor, I pirated it off of Jerry's website: TomC 'Crabs
TomC '90ZR1 #792 Honorary Pirate [B]If it ain't FUN, you're doing something terribly WRONG. [/B] Last edited by tccrab; 02-07-2011 at 08:54 PM. |
02-07-2011 | #3 |
I bought a GM AC seal kit with o-rings from NAPA and one worked perfectly....can't remember which one, the oring must the perfect size or it will not fit. These were the green o-rings
02-07-2011 | #4 |
Thanks Tom.. I got an email from Jerry and he gave me the size for the ''O'' ring. He mentions the "Buna-N size: AS558-017. So what do you think here?
02-07-2011 | #5 |
NAPA 801207 had one that worked for me
$3.99 That was pre-Jerry
02-07-2011 | #6 |
Steve:
If Jerry says Buna-N will work then it will work. Seems to be a standard size, 11/16 x 1/16, any parts store should have 'em. TomC
02-07-2011 | #7 |
Thanks guys. What I know about Viton or Buna-N ...it's all Greek to me. When you don't know about something surround yourself with people who do. I appreciate the help.
